6 lug 14 bolt FF
Discussion in 'The Garage' started by 98sub454, Apr 3, 2003.
  1. 98sub454
    98sub454 Registered Member
    Jul 18, 2002
    74
    La Habra, CA
    I found a '90 suburban parts car and one of the things im planning on taking out of it is the rear end. its a 2wd with a 454 in it and im not sure if its a SF or FF because i havent seen it yet. does anyone know what it would be for sure????
    also my main question is what can i do to keep my 15" 6 lug wheels?
    If its a SF i can get 6 lug axles right???? or wheel adaptors
    and if its a FF is my only option the wheel adaptors??
    i did a search and couldnt really come up with anything besides the adaptors, so any other info would be appreciated, thanks. /forums/images/graemlins/k5.gif /forums/images/graemlins/burb.gif
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Re: 6 lug axles
    If it is the FF with 8 lugs then the adapter that Echobit sells is the most practical solution if you want to keep your 6 lug rims. Anything else would require way too much trouble and money.
  3. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    Re: 6 lug axles
    i was looking at those and it says something about machining the drums. what exactly has to be done?? also i saw that is has only 6 holes. do you just remove 2 studs to bolt it on or am i missing something?
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Re: 6 lug axles
    If its a 2wd 454 Suburban it will be a 14FF 8 lug.
    John [​IMG]
  5. rebelk5frk
    Dec 29, 2001
    815
    Houston, TX
    Re: 6 lug axles
    2 of the lugs from the axle still go on the wheel.
  6. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    Re: 6 lug axles
    these are the ones im talking about, they only have 6 holes
  7. Grim-Reaper
    7,385
    Atlanta
    Re: 6 lug axles
    Are those steel or aluminum?
  8. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    Re: 6 lug axles
    look like aluminum to me... or as a limey would say "aluminium". /forums/images/graemlins/grin.gif
    j
  9. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
  10. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    Re: 6 lug axles
    really? weird. maybe its the lighting... they look just like my perf wheel spacers... which are definitely AL-you-min-E-um. /forums/images/graemlins/tongue.gif
    j
  11. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    Re: 6 lug axles
    would i be better of with aluminum ones???
  12. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    Re: 6 lug axles
    aluminum is a fine material to use to make spacers... this isnt cheesy aluminium... its a really high strength aluminum alloy. I know the ones I got are a real work of machining art... very nice. You are wanting to run 6 lug rims on an 8 lug axle though... not sure is perf makes a spacer that lets you do that or not. /forums/images/graemlins/frown.gif
    j
  13. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    also what exactly needs to be machined to fit these?? is it the hub that sticks out of the drum??
    also would i have any problems running this with a disk brake conversion??
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You have to turn down the hub so that a 6 lug wheel will fit over it. You also can not run factory chevy wheels. You have to run aftermarket or Toyota wheels because they have a larger center hole.
