6 lug 14 bolt
Discussion in 'The Garage' started by RedneckK5, Aug 29, 2002.
  1. RedneckK5
    RedneckK5 Registered Member
    Aug 15, 2002
    42
    texas
    has anyone ever heard of a 6 lug 14 bolt rear end. i ran across a light duty 3/4 ton chevy with 6 lug wheels, is it a 14 bolt.
  2. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    they were in the 88 and newer light 3/4 ton. they have a 9.5" ring gear and simi-floating shafts.
  3. RedneckK5
    Aug 15, 2002
    42
    texas
    so it is a 14 bolt? would this be a direct swap to my 86 k5?
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It is a semifloating 14 bolt, not a full floating one. The similarities between the FF and SF are... they both are called 14 bolts. None of the gut interchange between the two, and the FF is much stronger. Although the SF is still a whole lot stronger than the 10 bolt. You would have to change the spring pads and address and brake and u-joint incompatibilties, which it is likely to have. </font color>
  5. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    You'll have to cut and reweld the spring perches and get an hybrid u-joint from Jess at High Angle for the drive shaft. I believe it's 1310/1350.... I was gonna do this. Even bought one but I changed my mind for what I plan to do with my truck. They are plenty stong but the c-clips kinda suck. I'd suggest swapping over to disc brakes. You'll stop better and if you ever bust a shaft it won't come shooting out, the rotor will stop it....! /forums/images/icons/smile.gif
  6. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    you can make a 14 bolt FF in to 6 lug if you have the time and $$
