6-lug 14bsf shafts...where to buy from?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Apr 20, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I am going to convert my 8-lug 14bsf to 6-lug. Have any of you guys had any experience with buying aftermarket shafts and where from?
    Also, since I am going to replace my axle shafts would it be a good idea to replace the outer bearing? They spin fine but since I have it apart right now I was thinking about replacing it as well as the outer axle seal.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    while we are on this subject now, id like to see if i can find out what the official first year of 6 lug 14 SF trucks were, 2wd or 4x4
    any ideas ?
    good luck 88K5 wish i knew where one such axle 6 lug version was for parts or whole for ya for a good deal /forums/images/graemlins/laugh.gif
  3. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I know for sure the 6-lug 14bsf rear ends were in light duty 3/4 ton pickups starting in 88. I had found an 88, 2wd donor rear end to pull shafts from but the shafts were too short. They were actually shorter than my 8-lug shafts from my 82 14bsf I have talked to a few guys and have pretty much nailed down the year for the correct length shafts starting in 92.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Wouldn't it be much easier to just get the 8 lug to 6 lug adaptors ???
  5. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Why not buy a 14b ff, then convert it to 6 lug and sell the 14b sf? If you are going to do all the work of making an axle 6 lug, might as well do it to an axle that is stronger IMO.
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Because its a huge boat anchor & swapping shafts on a c-clip rear is about as easy as changing the gear oil.
  7. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Yes it would. That was my original plan, but the 8-lug drums I have are too big. My 15" wheels will not clear the drums.
    Good plan but not for my application. Right now the Jimmy is my daily driver so I don't need the extra weight of the 14bff and I am pretty conservative offroad. Plus I am pretty confident that the 14bsf will be just fine form my driving style and 36" tires.
    However, Z3PR gave me an idea. Are there smaller 3/4 ton 8-lug drums out there? I measured the inside of my wheels and they are a little over 14". Were there any 13" 3/4 ton 8-lug drums made?
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Keep in mind that the adaptors will move your wheels out by 1.5" on each side, so you just might be able to clear the drums depending on the back spacing of your rims.
