6 lug bolt pattern????--The IFS vs. SFA
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ut77gmc, Apr 21, 2003.
  1. ut77gmc
    ut77gmc Registered Member
    Nov 29, 2000
    65
    Salt Lake City, UT
    I get much conflicting information and flunked on the search on POR {lots of swapping going on there} and here.........
    I've got a line on a nice set of 6 lug 16" wheels/tires with Michelins that I can trade for my 15" 6 lug wheels/tires (Pep Boys sweeties /forums/images/graemlins/rolleyes.gif ) on my 'burb.
    QUESTION: Has anyone swapped an IFS 6 lug to a SFA bolt pattern?
    TIA......
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I believe they are all the same 6 on 5 1/2. All six lugs are the same as far as I know.
    -Brian
  3. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    the differnece i would be concerd about would be the hub cutout, but it should be the same. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    The backspacing might be diferent too. Some IFS systems run more backspacing in their rims, not sure about GM though.
  5. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey....
    I have 2 of those rims that you speak of. They will fit on a semifloating rear axle..but they will NOT fit over the hub on any front axle. Also...THe backspacing is fairly deep so it might not work on a 14sf...because of hitting the brake drum.
    Blake
  6. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Aftermarket wheels usually have a 4.25" hole in the middle (to make easy use of common centercaps). Stock SFA wheels have a 3.5" hole in the middle. You need to find a wheel with a 3.5" or bigger hole in the middle. Just about all wheels have that size hole or bigger. Even most 'yotas came with holes bigger than that in the middle.
    Next, IFS trucks have 14mm studs whereas we have 7/16" studs. That means if the wheels are thin steel the cone of the 7/16" lugnut will go through the 14mm-designed hole and hit the rotor/hub/drum without pinching the wheel.
    Lastly, you have to watch backspacing. Most IFS stuff has around 5.5" of backspacing. Put a 16" 5.5" backspacing wheel on a SFA and more than likely it'll rub on the centerlink ends. I know it will on a 15" wheel but I suspect it'd rub on a 16" wheel as well.
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have a set of aftermarket aluminum wheels that came off a IFS truck. bolted on like they came that way /forums/images/graemlins/thumb.gif. i have to use my old lug nuts though. /forums/images/graemlins/deal.gif
  8. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    You can take the late model 6-lug wheels to a machine shop and have them cut the middle out so it clears the hub.
  9. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    Are these wheels off a 1500 4WD or the light duty 2500 2WD. The 1500 4WD rims will have the deep backspacing while the light duty 2500 2WD rims have less back spacing and may fit the SFA better.
    (edit 5 years later) The light duty 2500 2wd rims have a smaller hole in the middle won't fit the hub on the sfa.
