6 lug hubs for 14 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Dec 5, 2001.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Is a 6 lug hub for a 14bolt ff common? Is it an aftermarket specialty item? Just curious cos I really like my wheels and tires and don't want to get rid of either! Is it a whole axle? Or a splined hub, by the way?
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    No, not common at all.
    There is a member here who took a regular 8 lug bearing hub and machined it down to fit the 6 lug wheels and redrilled the holes, too. Can't remember who it was though. [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    I think it was Donavon that did that? Not sure though.[​IMG]
    <a target="_blank" href=http://community.webshots.com/user/k5junkie>My Photos</a>
    <a target="_blank" href=http://www.geocities.com/jmargtx/index.html>My Webpage</a>
  4. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    How hard is it to machine down the 8-lug bearing hub and redrill the holes?? Can you do this without removing the axle shafts?
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Donovan does that mod.Heres pics of his stuff community.webshots.com/user/beaterwhang
  6. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Did one my self this week, I turned the hubs down on a brake lathe for mine and had a local shop bore the hubs out for 6 bolt. The shop also truned the axels down to match.
    72 Blazer CST 400TPI NV4500 NP203/205
    01 Suburban 8100 2500 4X4
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What is your total estimated cost for the conversion to 6 lug?
    My Chevy isn't broken, its just out of gas.
  8. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I'm getting ready to dig myself into a 14 bolter!!!! When you bored out the hub did you have to fill in the other holes? Is there room for fourteen holes on the hub? And what'd it cost? kinda, sorta, give or take a few bucks?
    Jim
  9. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i cant believe he went to all that trouble to save the ugliest wheels made
    you can buy those in 8 lug for next to nothing
  10. blazer72
    Apr 13, 2000
    939
    KCMO
    At this pont I have 200 in the axel, 40 in spring pads. 20 in new 1/2 wheel studs and 100 for the hubs to be milled out for the 6 bolt patern. pluss about 4 hours of my time on a auto parts brake lathe. I just did not want to buy 7 new wheels 7 new tires, plus the cost of changeing over the front to 3/4 ton hub and junk.
  11. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>blazer72, how did you set up a brake lathe to machine a 14ff hub? I'm guessing with the drum bit?
  12. blazer72
    Apr 13, 2000
    939
    KCMO
    Turned the bar upside down then used both the bit for the drum and one for the disc to get the cuts
  13. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    He was using that wheel as sort of a display with out showing exactly what was done.I dont blame him .Myself and others asked to see it w/out the wheel but he said no.
    Some people shouldnt drive anything bigger than their head.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  14. CarolinaBogger
    CarolinaBogger Registered Member
    Apr 17, 2000
    86
    Boone, NC
    What do you mean he said "no"? Why not?
    <font color=green>"I'm old enough to know better, but I'm still to young to care!"</font color=green><P ID="edit"><FONT class="small">Edited by CarolinaBlazer on 12/06/01 01:30 AM.</FONT></P>
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    Probably wants to play his cards close to his vest. [​IMG]
    If you figured out a way to do something, like this, would you want to tell everybody or would you want to try to make some money instead? [​IMG]
  16. blazer72
    Apr 13, 2000
    939
    KCMO
    Well I tell you what its not a big thing and there is no real money to be made here. My camra is out being fixed as sone as it gets back which is friday I hope I will take photos and post them. I reused the disc that I had on the warn kit and fited the out side of the hub to the wheel which is a about 4.175 in dia. The inside is 4.168 the studes are 1/2 2.75 long. We talked about the hows and why and I tryed to talk to Dorean but got nothing. The hub centers up very nice in the bearing races on the lathe by the way.
  17. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Yup ,what K30guy said [​IMG]
  18. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    That makes sense to me. As far as Im concerned, 3/4 ton front end stuff is junk. Its just a 1/2 ton axle with extra weight added by the heavy rotor/hub assembly. One good thing I have heard about it over 1/2 ton is braking ability. I guess they have better calipers or something.
    I think you did the right thing Ken, plus thats one trick mod. Dare to be different.
    Mudzer 1978/91 K5
    <font color=blue><a target="_blank" href=http://www.mudzer.rockcrawler.com>www.mudzer.rockcrawler.com</a></font color=blue>
