6-lug to 5-lug..........
Discussion in 'The Garage' started by dontoe, Oct 25, 2006.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Are rear axles the same...........6-lug vs 5-lug as far as swapping axle shafts?
    The fellow that I got the Stepside from swapped axles. Now it's a 3.08 and it needs a 4.10 since it's a 250-6 cylinder! If I find a 60/14 combo I can afford I can use the 12 bolt from the Blazer, maybe!
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Yes, axles the same, except for the lug pattern. Swap away!
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    x2 . 2wd housing under my truck with six lugs in it :thumb:
