6 lug to 8-lug parts?
Discussion in 'The Garage' started by firefighter184, May 3, 2007.
  1. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    I need a complete and accurate list of EXACTLY the parts I need to convert my 6-lug 10bolt front to an 8-lug. Even better, if anybody with a huge brain and free time is bored, NAPA parts numbers would icing on the cake...
    I love you guys.:D
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    All you really need is the correct size spindles and bearing hubs. They made two dif sizes. small bearing and big bearing spindles. I'm about 96% certain the calipers are the same and you should get 3/4 ton pads cuz they are taller- bigger rotor but you can live with 1/2 ton pads. They just won't utilize the inner most part of the rotor brake surface.
  3. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    you dont need new spindles... all you need is the backing plates, the hubs and the rotors
  4. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
  5. goldwing2000
    goldwing2000 Guest
  6. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    cajun is correct. pretty simple, actually.
  7. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Yes- x2 but you have to make sure the spindles match your hubs. Forgot about the backing plates
  8. goldwing2000
    goldwing2000 Guest
    All 10-bolts have the same spindles, so he should be fine.
