6 lug to 8 lug question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Obsession, Nov 20, 2001.
  1. Blazin Obsession
    Blazin Obsession Registered Member
    Sep 25, 2001
    64
    B.C Canada
    I am gathering up the parts to go to a 14 bolt diff and am going to convert the 10 bolt front with 6 lug to 8 lug. And the million dollar question is,,,,,,,,,,,,, can I use the brake backing plate from a 2 wheel drive 3/4 ton or do I have to use one from a 4x4?????
    Just a note,, I bought a 14 bolt diff with 4:10 gears and took it a part to check things out ,and wow,,,,is this thing ever a superior design compared to my 10 bolt,,, cant wait to get a locker and get it all installed.
    Ken
    <a target="_blank" href=http://www.blazinobsession.com/>http://www.blazinobsession.com/</a>
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    You will need the plate off a 4x4. The 2wd stuff is totally different.
    And yes, it will need to be from a 3/4 ton also. The 1/2 ton plates are a little smaller in diameter than the 3/4 ton.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
