6 lug vs 8 lug
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tom, Dec 20, 2001.
  1. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    Which is easier and cheaper. Converting a 6 lug 10 bolt front to 8 lug, or converting an 8 lug FF14 to 6 lug?
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Converting a 10bolt 6 lug to 8 lug. All the parts are bolt on. The 14 bolt conversion takes custom work. If you need to know what to look for just ask.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    If you can do the machine work yourself then converting a 14 FF would be cheaper since all you need is new bolts for the cover, and new wheel studs.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    To have your 14 bolt converted to 6 lug is about $400 .Cheaper if ya can do it your self.To convert the front from 6-8 or 8-6 lug is in the 2-$250 range for used backing plates,hubs, and rotors.
    Some people shouldnt drive anything bigger than their head.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Go 8 lug, 15" 8 lug wheels are cheaper than converting a 14 to 6 lug
  6. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Wouldn't it be easier and cheaper to replace the front 6-lug 10 bolt with an 8-lug D44?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  7. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    no it would not.its cheap and easy tp convert a 10 bolt or dana 44 to 8 lug.all you need are caliper stands hubs,and rotors.calipers are the same.
    eatin'fords and shittin'dodges down in the sunshine state.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why would you want to do that when both 10 bolts and D44s have 8 lug versions and it might not have the right gears?
    Tim
