6 Mpg On Stock Blazer
Discussion in 'The Garage' started by Guss, Sep 4, 2005.
  1. Guss
    Guss Registered Member
    Feb 6, 2005
    78
    houston
    I Did A Tune Up, Oil/filter Change W/ Mobile 1 And Still Only Getting 6 Mpg Help!!
  2. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    stock size tires ?
  3. Guss
    Feb 6, 2005
    78
    houston
    31x10.5
  4. gmcjimmy90
    gmcjimmy90 Registered Member
    Jul 3, 2005
    76
    arkansas
    what year,motor, trans ,gears ,tires.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    egg or large block of wood under the pedal. My 84 only got about 6mpg.
    If carbed did you rebuild or have the carb rebuilt? Don't expect miracles, it will likely jump to a massive 10mpg if there IS something wrong.
  6. Guss
    Feb 6, 2005
    78
    houston
    tbi 350. 700R4, w/ 3.73 gears shold be alot beter than 6 im realy scratching my head. it doesnt miss or anything just sucks alot more gas than it should
    and to the egg thing i drive it like a grandma anyway.
  7. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    running way rich or is that how much gas the engine likes? also try the O2 sensor. wont help alot but maybe a little.
  8. gmcjimmy90
    Jul 3, 2005
    76
    arkansas
    try changing the fuel filter i have 165000 on my 90 gmc jimmy, and it gets about 15mpg
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    do u have full exhuast on it? when i jus had a y pipe on, i was only gettin 4mpg. other than that i dunno what to tell you :confused:
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    check your timing, and fuel pressure. also, start driving like a normal person.
  11. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    If non of the above works have a scanner put on it and check the coolant temp sensor. If it is telling the computer that the engine is still cold when it is warm then it will run full rich (just like a choke on a carb staying on).
  12. Guss
    Feb 6, 2005
    78
    houston
    would dirty/leaky injectors do the same thing?
  13. gmcjimmy90
    Jul 3, 2005
    76
    arkansas
    yes it could also have the cat checked
  14. Guss
    Feb 6, 2005
    78
    houston
    recently put exaust on w/ cat but did notice injectors had partial spray with some..... not quite a drip but not a fine spray also looks like the injector seals
    might be leaking. do they make a rebuild kit for the throttle bodie
  15. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    The good thing about tbi is you can turn the key on and let the fuel pump cycle and watch the injectors. If they are that bad you can see them leak down. If it is a slow leak use a pressure gauge and see if the pressure leaks down.
    Yes you should be able to get a rebuild kit from any local parts store.
  16. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    thats funny, last fall my K-5 was having similar problems with fuel milage but turns out to be a faulty wire in the system, i bypassed the fuel pump relay completely, and now when i turn the key on the fuel pump does not cycle it stays on all the time :crazy: :crazy: :crazy: hehehehe. i like it, i get almost 20 MPG with 38.5 swampers on it.!
    LUKE
  17. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The throttle body repair kit will only set you back about $30-35, depending on which throttle body you have. Remove the air cleaner and look closely at the front left edge of the throttle body housing. You need that 8 digit number when you go to buy the kit, to make sure that you get the right one. GM used a LOT of different throttle bodies!
  18. Guss
    Feb 6, 2005
    78
    houston
    thanks guys. 20mpg on 38s wtf how is that possible
  19. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Before you do anything check for trouble codes. Even better buy a Scanner! Like an auto X ray or something.
    One of your sensors may be bad and the ECM is in limp home mode. That will usually cause a very rich condition and lousy fuel milage.
    You should be getting way better than 6 MPG with TBI 700r4.
    I get 18 MPG highway on 33 MTs 3.73 gears in an 89 TBI
  20. gmcjimmy90
    Jul 3, 2005
    76
    arkansas
    sorry to hijack but what if any mods do you have to get 18mpg's
