6" or 4"+2"?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by horsepit, Jan 11, 2002.
  1. horsepit
    horsepit Registered Member
    Nov 25, 2001
    63
    Ventura, CA
    6\" or 4\"+2\"?
    It sounds like there are a lot of alignment issues when you go to a 6" lift. What is the benefit over using a 4" with a 2" body? I'm not a rock crawler, street and mud only.
    1987 Blazer, TH700R4, NP208, 3.42, Rancho 4", 33"
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 6
    For mud, getting the frame farther from the ground is always better. If either is an option, I'd go 6" suspension.
    That said, I have a 4" suspension and I'm adding a 3" body lift. If that's not enough I'm going to put a 6 or 8" suspension lift on it. I am doing it for financial reasons. One day I might end up removing the body lift because I don't particularly care for them. Another reason I'm doing it is because I'm taking the body off and doing a frame swap anyway, so it's easy to do it now.
    Tim
  3. horsepit
    Nov 25, 2001
    63
    Ventura, CA
    Re: 6
    8"? That must require a lot of mods right? What do you have to do for a 6" and what for an 8"?
    1987 Blazer, 350, TH700R4, NP208, 3.42, Rancho 4", 33"
  4. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Re: 6\" or 4\"+2\"?
    Depends on how big a tire you want to run. I have 4" lift and cut out fenders, I run 36x14.5x15's on mine. Keith has 6" lift and just killed his front drive shaft, he also has 1" body lift and runs 38's I like as little lift as possible and wont use a body lift at all.
    Depdog
    <font color=blue>Weenie K5, little mods' Small Tires!</font color=blue>
    <a target="_blank" href=http://depdogsk5.coloradok5.com>depdogsk5.coloradok5.com</a>
  5. k5'er
    k5'er Registered Member
    Nov 29, 2001
    92
    PA
    Re: 6\" or 4\"+2\"?
    id go with a 6". i have a 6" lift and run 35's. i think i could go a little bigger though.i had to lengthen the front and rear drive shaft, and lowered the tansfer case a little to help with angles. i disconnected the brake lines from the frame and brackets, rerouted them and let them hang.6" isnt that much more money,and in the future you could get a 3" body lift for not much and get a quick 3 more inches. its all personel preference though. just my 2 cents.
    Mud! Its cool!
  6. scotty1
    scotty1 1/2 ton status
    Jan 7, 2002
    166
    WV, Harpers Ferry
    Re: 6\" or 4\"+2\"?
    The nice thing about a body lift is that the center of gravity is not raised as much as a suspension lift. There will be trans linkage and steering issues and sometimes a grounding strap will need to be lengthened.
    Git there fastest with the mostest!
    Nathan Bedford Forest
