6 pin connector questions.
Discussion in 'Tow & Trailer' started by divorced, Dec 23, 2005.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Ok, so I have some trailers that all have the crappy 4 pin connectors that never work right. I bought some 6 pin connectors to use instead. What does the black wire do in the pic below?
    I don't have trailer brakes, so I may use one of the extra pins for reverse lights, but I need to know what the black wire does, because I may put the reverse lights there.
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    Doesn't it say 12 volt on the diagram? I would just assume that is power.....
    for whatever you need it for. Since the rest im assuming is positive trigger (where ground is constant),
    there isn't a specific use for teh 12 volt as i see it described.
    Really i don't know, just brainstorming outloud i guess
  3. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    for 12v power to some other use in the trailer you designate it to be. and why 6 pin? most all are 4 or 7 pin that i have seen. but now it will be harder to let someone use your trailer if thay dont have a convertor unit. :D
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    THe black is 12v constant hot. It's designed mainly for an enclosed trailer. (my experience) where there will be a wall mounted toggle for lights inside or outside the trailer. This is how our sled trailer is set up. It has two rockers inside for interior lights and loading/unloading lights.
    IIRC, there is no spot for reverse on a 6 pin, but I may be wrong on that. I just converted a 6 pin to 7 pin the other day and the 7 pin has a spot specifically for hot only when in reverse.
    You COULD essentially convert your truck's 12v constant to a reverse light if you wanted. Obviously by disconnecting that pin and splicing into your back up lights. BUT, I normally don't recommend changing stuff around because it causes a headache when someone else uses your trailer or you use someone elses pickup. What will happen is your back up lights will be wired constant hot with a different pickup setup standard. :doah:
  5. divorced
    Jul 20, 2004
    5,115
    6 pin is what they had cheap at Napa in town. There are a lot of livestock trailers around here that use the 6 pin. I can buy a 6 pin to 4 pin adapter for under $10 bucks so I can still pull a 4 pin trailer, and not being able to let others use mine is a bonus :D
  6. divorced
    Jul 20, 2004
    5,115
    Ya, I never thought of it like that. I'll still think about it some more... reverse lights aren't really a necessity. I may wire the +12v lead as in the picture so I can use it to charge a winch battery or operate some type of cargo light on the trailer.
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I have a trailer with two large back up lights and with the 7 pin there is a spot for reverse. I haven't really benifeted it from the lights all that much, I can still see really well around it at night.
    Remember that your constant 12v is constant, even with the ignition off. So be carefull to not run your truck batteries down.
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I think the constant 12V is for things like charging a battery on your trailer or recharging a breakaway kit if you have one. I do not know the size of the wire but charging a battery might be excessive.
    Ira
  9. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Or you can use a Relay on the truck to shut off the 12V line when the truck is off. I'd wire in a manual override switch though incase there is a need for that line with the truck off.
  10. apcon
    apcon Registered Member
    Sep 5, 2006
    53
    Trotwood Ohio
    As someone who installs reciever hitches, goosenecks, etc. professionally the black 12V lead is for mainly trailers with electric brakes who have a breakaway kit to keep the battery charged. i have also seen many enclosed cargo trailers have their 12V interior lights either run directly to that pin to power them up off the tow vehicle or more often they're run off a automotive battery mounted in a box on the tongue of the trailer that has the charge lead off the pigtail connected to the positive post so that the battery recharges while going down the road. the charge wire will recharge a fullsize battery as most oem and aftermarket wiring installations feed 30 amps to that pin of the plug. the main difference between a 6 and 7 way plug is that the 7th pin is dedicated for backup lights.
  11. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Agreed...The 12V circuit is to charge the breakaway battery or marine/RV batt. if you have them on a camper or winch etc. Chevy now supplies this circuit with 40A and 10ga wire in their tow packages. Just remember that it is constant 12v even with ignition off, so if you don't install a relay unplug the trailer if it will sit for more then an hour or so, or you may end up with a dead truck batt.
