6" REAR SPRINGS W/SHACKLE FLIP?
Discussion in 'OffRoad Design' started by clarkjw24, Mar 1, 2004.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    6\" REAR SPRINGS W/SHACKLE FLIP?
    I'm running 6in rear springs but I want to run a set of something like the revolver shackel. What are my options? Does ORD make anything that would work like a shackel flip with no height added. I've got a 2in body lift also. /forums/images/graemlins/dunno.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: 6\" REAR SPRINGS W/SHACKLE FLIP?
    they make a 2.5" shackle flip, a no lift setup would put the shackle mount up in the area of the frame. meaning you would have to drill a hole through your frame to put the nut on the bolt. Meaning anytime you wanted to unbolt it you'd have to drop the tank.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    About as good as you can get is the 2.5" lift, I'm not sure what to tell you from there. A no lift compression shackle setup would have to look something like this:
    Rear shackle
    The height of the mounting point may even have to be higher than shown in the pic. The flip kit in the pic is a 2.5" lift version.
