6" spring all around... ?'s
Discussion in 'The Garage' started by stockk5, Oct 13, 2005.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Well my bro wants to know if we can install his super lift 6" kit.. full springs w/ out having to get longer drive shafts... is it possible? i keep finding mixed answers...
  2. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I have been wondering the same thing. I know you CAN because I just test drove an 80 Blazer with a 6" Superlift and factory shafts. That said it did seem to have a bit of vibration. And what about off road?
  3. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    i did it in my 84, but i used blocks in the back
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have some rear 5.5" SkyJacker springs that have the hole drilled about an inch forward of the normal spot, so no driveshaft mods were necessary on a K5. It really depends on the vehicle; almost all are different.
  5. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Why would it differ from blazer to blazer?
  6. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    yeah im kinda confused on that one...... im talking just bolt in a regular 6" spring into the exact same spot as the old spring.. will a new driveshaft be needed front/rear...
  7. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    I have an 86 chevy longbed and a few years ago I put a 6in. lift on it. I installed 6 in. skyjackers in the front and 5.5in. blocks in the rear..the rear shaft was fine, the front shaft worked but I had it lengenthened a little anyways because offroad it would come apart. Hope that helps.
  8. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    i wondered that too....but some people have problems and some don't
  9. divorced
    Jul 20, 2004
    5,115
    I don't know for sure, but that's why you get conflicting answers when you search. Some trucks need longer shafts and others don't, especially with 6" lifts, it's real borderline. The transmission/t-case combo can affect this also because they are different lengths. And the way the spring is manufactured will vary between brands.
  10. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    ah ok i gotcha... well 700r and 208... dont know if anyone knows if this is one of the longer ones? its just a big deal cuz thats an extra lotta money he doesnt have to lift his truck.. as well as mine pretty soon..
  11. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    I have a six inch spring lift with 35's and I have had no problem at all. No vibes, no breakage. D44, 14ff, 350, sm465, np208 and stock shafts.
  12. REDCRO_REDNECK
    REDCRO_REDNECK 1/2 ton status
    Apr 7, 2005
    241
    mo
    another thing to remember is that if your truck is converted to 3/4ton the 14 bolt will make up some driveshaft length because of the longer pinion. not much but every little bit helps
  13. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    hey man dont u have a longer bed pick up though? or is a shortbed pick up the same length as a blazer? thats gonna be my exact set up for axles...
  14. durantk5
    durantk5 Registered Member
    Mar 1, 2005
    50
    Greensboro, NC
    i have the 700 and 208 combo with 6 inches of lift. i have stock driveshafts.i have a little vibration at lower speeds but thats it. no problems off road so far.
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I had too have longer shafts when my 76 K5 grew 6 inches.
  16. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    oh man... i dont know how u guys do this....at this rate my truck cant grow up until 2007.....
  17. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    I did 6" skyjacker springs front and rear on my 91 K5.
    Had to drop the transfer case and put angled spacers under the front n rear springs. Other than that every thing fit fine with no mods to shafts
  18. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    realllly? haha i like this glimmer of hope thing, i guess basically its a crap shoot and jsut gonna have to try it? what degree shims did you use?
  19. badfish4tail
    Mar 1, 2005
    1,684
    Long Beach
    If i recall correctly :rolleyes: I think it was a #4
  20. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    They may work for street use, but if you flex the suspension, they more than likely be to short.
