6" spring question removing leafs adding zero rate??
Discussion in 'The Garage' started by MTBLAZER89, Aug 31, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    6\" spring question removing leafs adding zero rate??
    OK trying to soften up some 6" Rancho springs. Is it a good/bad idea to remove couple of leaves and replace with a 0-rate? Will this work and keep about the same height?
  2. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    Re: 6\" spring question
    i pulled out the 3rd longest on my bds... i like it
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Since when does rancho even make 6" leaf packs? Or are they old?
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Not sure how old they are they are on a K5 my buddy just bought he was told they were Rancho. They are stiff /forums/images/graemlins/yikes.gif
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Re: 6\" spring question removing leafs adding zero rate??
    anybody else /forums/images/graemlins/dunno.gif
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    They may wear out faster but I doubt it, you can try just the bottom leaf and see how much it helps and then go from there.
  7. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Another member on this site told me that when he removed the very bottom leaf from his 6 inch pack, it rode a bit better and that it lowered it just a hair. Probably an less than an inch.
    I'm planning on doing the same with mine to get a smoother ride and to drop it a little bit.
    Blake
  8. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    cool trying to keep it at the same height so remove an inch of springs prolly 2 /forums/images/graemlins/dunno.gif and add a zero rate to move the axle forward cause the front driveshaft only has about 1/2" of compresion /forums/images/graemlins/yikes.gif
  9. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Just FYI, I've already broken a 6" TC front main leaf. The only mod I did to it was open up the spring clamps.
  10. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    anybody know which spring or springs are the best to remove?
  11. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    take off the top leaf, then every second leaf after that until you got the hieght you want /forums/images/graemlins/thumb.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would start by taking out the shortest leaf.
  13. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i agree
  14. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    im happy with the 3rd longest... you dont wanna take the second longest and risk snapping the main leaf, and i dont think anything down bottom does much to stiffen the ride, so leave them
  15. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Um, the shorter the leaf the harder it is to bend. Start with the shortest and work your way up.
