6" suburban lift
Discussion in 'The Garage' started by crash81, May 1, 2006.
  1. crash81
    crash81 1/2 ton status
    Jun 19, 2005
    289
    roxboro,nc
    i need a drop pitman arm to help correct my steering after the install of a 6" lift. i already put on a raised steering arm but it steal has bad bump steer and a very bad turning radius. will the pitman arm help and where is the best place to get it? i would like to use a vendor from here if possible. thanks in advance
    Dudley
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Have you checked your dle's and tre's? If they are worn, you can get some killer bumpsteer.
  3. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    i tryed both with 6" lift. wont help will make the drag link angle wrong and not steer correctly.
    the stock setup sucks with more than 4" lift. just save the pennys and to cross over at 6" and up for best results.
