6" suspension, 2" body: too tippy? any pics?
Discussion in 'The Garage' started by steelsoldiers, Sep 9, 2003.
  1. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    6\" suspension, 2\" body: too tippy? any pics?
    That's what I'll end up with after I do the 6" springs up front and the shackle flip with my 2" springs in the rear. I'm trying to decide if I should keep the body lift or not. I'm planning on 39.5x13.50-16 Swamper Iroks. I run lots of old logging trails which can get a little off-camber sometimes so I'm looking for firsthand info. Thanks. /forums/images/graemlins/grin.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 6\" suspension, 2\" body: too tippy? any pics?
    <font color="green"> I can tell you that my 6" lift with 38s got a little tippy sometimes, but I was also running a wheel offset that basically kept the entire 15" wide tire under the fenders. If you run a bit more offset then you'll be a little less tippy, but the extra height would probably negate that. I guess alot is going to have to do with your definition of "a little off camber".</font>
  3. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I have 6" susp and 3" body lift. With my tall skinny LT235's, it definitely felt very tippy. I just installed 38x15.5x15's on wheels with 3.5" backspacing. I haven't trail tested it yet (still breaking in new engine), but she sits pretty wide, and doesn't look or feel tippy now. E-mail me in a few weeks, and I'll let ya know!
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I run 12" suspension lift with a 2" body lift.I have 44" swampers on 16.5 x14 weld rims with enough back spacing so the tires are wide enough to keep it from tipping over.At least so far.
  5. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    5.5 BDS all spring suspension
    1" ORD Body lift
    1" ORD Zero rate/frt Dana 60 (raised spring plate add's an inch)
    Currently running 37" SSR's as pictured, but I have plans on 40"MTR's
    I dont think that its tipsy one bit, by the way, I don't run the swaybar do to the X-over steering. If I do want it to handle like a sports car... /forums/images/graemlins/smirk.gif, I can just air up the Rancho's to thier max capacity.
  6. CK5
    May 19, 1999
    21,623
    701
    CO
    I seem to recall this feeling "tipsy"
  7. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Click on my link to see my truck, I have 6" susp, and 3" body with 44's. I haven't had any major sphincter pucker factors yet. Why not try it out, you can always remove the body lift if you dont like it.
  8. steelsoldiers
    Oct 17, 2002
    365
    Thanks guys, you've convinced me. I mean, the body lift is on there already so why not run it for a while and see what it feels like right? I have the Warrior sway bar disconnects which are supposed to be for a 4-6" lift so that should help me on the way to the trailhead. If I have to take the body lift off, out comes the Sawzall! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    i run 5.5" of suspension lift, plus 1" of body lift on 39.5s... works for me. I take corners nice and slow (no antisway bars on my rig) but other than that it works gr8.
    j
