6 to 8 Lug Adapter ???
Discussion in 'The Garage' started by Indyblazer, Jun 6, 2005.
  1. Indyblazer
    Indyblazer Registered Member
    Apr 24, 2005
    35
    Indiana
    Is there any such thing as an adapter that allows an 8 lug rim to mount to a 6 lug hub on a K5 ??? If so, where do I buy one ? (Someone is looking to buy a set on the parts forum)
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I dont believe so, but you can just convert the 6-lug hub to 8-lug. Im assuming its the front axle you are talking about. If thats the case, all you need is to find a 3/4 ton chevy truck with a d44 or 10 bolt in the front that is 8-lug (the junkyard is the best place to find this). Then just remove the hub/rotor assembly, and the brake backing plates. Then just install them on the blazer with the 1/2ton locking hubs, and wallah you have a 3/4 ton 8-lug front end.
    -Harrison
