6 to 8 lug adapter
Discussion in 'The Garage' started by Hossbaby50, May 13, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I know that they make a 8 lug to 6 lug adapter. But does anyone make a 6 lug to 8 lug adapter?
    I ran into a little dilemma the other night. I am planning on building an offroad only K5 with 1/2ton axles. (I don't want to hear it, it is going to be light). My current K5 is already swapped over to 3/4 ton. I want to run 1 set of tires for offroad and share them between the 2 trucks. I already have a set of 35's for offroad, and I am planning 38" TSL's. I don't want to have to buy 38" TSL's twice. So how do I get the 1/2 and 3/4 ton axles to matchup lug wise?
    I don't want to convert my current truck back to 6 lug. I like the extra beef on the wheel studs, and I already payed to convert it once. I also like the looks I get when people realize that my truck has 8 lugs instead of 6.
  2. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Send a PM to TonyP on this board. He is the one that made my 1.25" spacers and he is also the one who makes the 8 to 6 adaptors. I don't see why he wouldn't be able to make a 6 to 8. He does good work. /forums/images/graemlins/thumb.gif
    -- Mike
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Will do. Thanks
    Harley
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    hey, that would be do-able going from 8 lug to 6 lug, if you can space your tires out 1" inch per side then a spacer ring will do the job...
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Spacing the tire shouldn't be that big of an issue. This truck it is planned for will have quite a bit of fender trimming and the rims I will use have 4 1/8" back spacings so it shouldn't matter.
    I emailed you back by the way.
