6 to 8 lug conversion for 10 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DwarF, Apr 9, 2002.
  1. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    About the technical article about converting your Dana 44 from a 6 to 8 lug. He makes an offhanded remark about the same thing working on your 10 bolt.
    My question is, has anyone with a 10 bolt tried this out yet? Do the Dana 44 hd spindles fit the 10 bolt? I have a couple 10 bolts, so I would like to try it out, but if I am goin to spend money on parts, the Dana 44's are cheap. So I am trying to decied if I should spend the money on the parts for the 10 bolt conversion, or on a whole Dana 44 hd that is already 8 lug.
  2. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    You don't need the spindles from the 44, just the backing plates, hub assembly, and rotor. - Doug
  3. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Yes all the parts are interchangeable between the 10 bolt and dana 44. At least from the knuckles out. I got all the parts to convert my ten bolt from 6 to 8 for $150.
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    i got mine for 140!!! neener neener neener
    Later
  5. ca89blazer
    ca89blazer Registered Member
    Mar 2, 2002
    9
    Redding Ca
    I used outers from a 8 lug 10 bolt to convert a dana 44 to 8 lug.
