6" vs. 4" lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Mar 18, 2000.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    6\" vs. 4\" lift
    What would I have to do different for a 6" as opposed to a 4" lift?? What all would I have to do to the drive train and whatever else is needed to be adjusted for a 6" lift?? I know that with a 4" lift there isn't anything but steering that needs to be changed. I have a 4" lift on my Jimmy right now and want to upgrade to a 6". Let me know what I'm going to have to do. Thanks
    Alex
    "What me get stuck? NEVER!!"(Famous last words)
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Re: 6\" vs. 4\" lift
    You need a brakeline-lenghten kit.New antisway-bar. And you need the longer steering-arm. The drivetrain will work as is, I know guys ride with it and they have no complaints. Everything wear's faster though, and should you really flex and bend I guess there could be a problem.
    Planing on a 6" myself. Its just a money-thing..[​IMG]
  3. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    Thanks that's what I wanted to know.
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>My dad just put a 6" Skyjacker softride system on his k10 and he used drop brackets to lower the swaybar. Disconects would do the same thing, and allow you to free the swaybar when off road, and then re-connect it for the highway</font color=blue>
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    in just installed a 4" lift on my blazer today....4.5 superlift blocks in the rear and 4 inch pro comp springs in the front....it me about 8 hrs to do and i had to change the rear brake line...i dident like the way it looked...dident have much slack left...i also changed the steering arm....that was a pain in the ass...that took me the longest to do (about 2 hrs heatin it up then wackin the crap out of then the back to the heat) but the rest went smooth..
    Chaz
    "The stuck lemon"
  6. Max
    Max 1/2 ton status
    Feb 19, 2000
    158
    Durham, NC
    If anyone is looking to get rid of a 4" lift....drop me a line: alan.baydush@duke.edu
