6 vs 7 prong
Discussion in 'Tow & Trailer' started by BurbLover, Apr 28, 2004.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    What's the big difference between a 6 pin round and a 7 pind round connection? I understand it's for auxillary, but what does that mean?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    used for either a reverse light on the trialer to assist in backing up as a 12 volt source for a battery charger.
  3. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    But the 6 show a 12V as one of it's wires. Wouldn't that be for that purpose?
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    That would work for charging a battery or accessories inside the trailer (dome lights, radio, etc). I'm happy using the 6 hole round connectors on just about everything. Most of the time I just have the bare minimum in use anyway (3 for lights, 1 for ground and 1 for brakes).
  5. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    So, would it be better to convert my 6 way on my truck to a 7 or convert my camper to a 6? The only other trailers I have are both 4 anyways, so no conflict there.
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I run a 7 way on my truck, then adapt down to 6 or 4 if needed for the trailer. The 7 prong is the big boy, and all the others can be fed easily off of it. Going the other way can have problems. The only gotcha is that the 6 way has 2 different "standard" pinouts. Basically 2 wires flipped for some trailers, but one is much more "standard" than the other... /forums/images/graemlins/laugh.gif
  7. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    I was kinda leaning towards the 7 prong just for the adaptability thing. Then I can just go to 7 on all my vehicles and I'll always be able to hook up to just about anything. I already have a 7-4 adapter. I'll just buy a 7-6 adapter & then I'll be covered.
  8. kennyw
    Jun 9, 2002
    13,223
    94
    For A camper I would go with the 7 way and adapt down if needed. I dont haul a camper around right now so a 6 round works well for me. Mainly have a flatbed trailer and a set of towing lights (used with a towbar).
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  10. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    I've got that diagram. The 7th pin is for "auxilary". SO, what the hell is that?
    Do I use that or the 12V for the charging system?
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I used the 12v pin when i did mine for the travel trailer charging system.
    Use the aux for like tailer back-up lights
  12. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    You could use it for backup lights on the trailer, or anything else you wanted. /forums/images/graemlins/waytogo.gif
