60 front pinion and knuckle question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chiefheaphy, Apr 10, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    Are there any good tricks to get the pinion nut loose. I'm trying to be smarter than the gear but I think my pinion is a genius. MAybe grab the yoke with some big jaws?
    Does the bottome plate on the knuckle just pry off? Should I heat it up ir just wedge something in there to pop it off.
    Do the inner axle seals just pull out?
    Do I make the biggest hex key in the universe to loosen the kingpin?
    B
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,993
    130
    I just grab the yoke and hit it with my impact gun. If you don't have air tools, try a pipe wrench on the yoke. It will take quite a bit of force to get off (~300 ft. lbs.)
    Does the lower cover just pop off? I think so.
    They don't pull out really. You have to remove the carrier and then get the old seals out (by prying them) and replace them. Getting the seals back in is a pain unless you have an axle seal installer tool
    Well, yes :D
    But, even if you make or buy a 7/8" allen wrench, you will have lots of trouble getting it out. They take 500-600 ft. lbs. to remove. Check this out:
    http://www.pirate4x4.com/forum/showthread.php?t=556811
  3. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    huge help
    that link is awesome
    thanks for the help.
    I'm having a hard time getting the lower piece out so the knuckle can come off.
    How do you like the 465? do you run hydro or mech?
    do you know anything about a 14ff out of a g30 van that is wicked wide? (wider than SRW 1-ton trucks?)
  4. 1977k5
    May 26, 2003
    9,993
    130
    I love my 465 and I still run the mechanical clutch. It works just fine for me.
    The only thing that might be different about that 14 bolt is the hubs may be different.
  5. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I had a hard time getting the lower plate off my 60 as well. I ended up working it back and forth with punch and hammer. It beat them up pretty bad so I replaced them. They are like $40 at Six States. Took me about an hour of beating on them a piece.
    As for the kingpin, it took three good size guys with a six foot cheaper bar to break them loose. As it was out of the vehicle we had to have a couple people stand on it to keep it from moving. Also, Grainger has the allen to fit it.
    Here is us working on the kingpin. LOL
  6. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Do a search on the allen wrench. I think someone came up with the idea of using one of the deep lug nuts and it worked great.
  7. Speedo
    Speedo 1/2 ton status Premium Member
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    I bought just the hex insert for a Snap-on 7/8" allen socket and use it with a 3/4" drive 7/8" socket.
    Gus
  8. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    king pin removal
    Problem solved!!!!
    I welded a 2" square tube to the the kingpin solid. Then quickly wrapped a pipe wrench around the square with a breaker bar. I stood on the axle and put my weight on the bar. Couldn't have been easier. Heat from welding contracts the kingpin. To put new ones on I found a 7/8 allen key at a industrial tool store in Lowell, Ma called McGlinterks. To punch out the inner seals I used 1 1/4 gal. plumber pipe(threaded) with a coupler. You will have to grind the coupler down till it fits in the tube. The toughest part of the teardown for me were the lower bearing caps. I had to carefully cut one side out.
    Some pics
    Anyone have any good ideas for parts renewal/rust removal im really getting sick of wire brushes on grinders and drills?
