60 vs. 14 bolt?
Discussion in 'The Garage' started by sled_dog, Oct 18, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Just as the topic says. I want to get specs of both axles.
    14 bolt
    Corp 14FF complete axle w/ disc brakes: 400#
    Corp 14FF complete axle w/ drum brakes: 475#
    Distance from center of axle tube to lowest housing point?
    Dana 60
    Anyone help me fill in the info here?
  2. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    complete 60 is #550
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    sorry, REAR 60 not front.
  4. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    This sucks, cuz I got one w/o drums that isn't in my truck, but I don't have a means to weigh it. /forums/images/graemlins/frown.gif
  5. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    goin out to measure the 14bolt do you nee exact measurement or close? /forums/images/graemlins/dunno.gif
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    close as you can. I'm not so qorried about the 14 bolt. I have my shaved 14 bolt I can measure. Stock 14 bolt number would be nice.
  7. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    just measured my stock 14 bolt ff. lowest point i say 7" that's with a tape measure and a steel rule flat against the bottom of housing to measure.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the shape of the 14ff housing is hideous
    I miss my d70
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I miss my d70
    /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/whistling.gif
  10. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I can probably measure my stock rear 60 tomorrow. I know its around 65" wms-wms, but that is about it. That and it's not staying in my truck for long.
  11. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I don't know the numbers, but I know the D60 rear that I sold a while back didn't weigh all that much. Probably close to that of a 10b, maybe just a bit more with the larger drums etc. As for the measurment.. wouldn't it pretty much be the same as a D60F? The housings are the same right?
  12. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    OK, went outside and got some measurements for ya...
    dana 60 rear, stock in my '69: approx. 5-1/4" from center of axle tube to bottom of diff. Axletubes are 3" in diameter.
    for comparison, my '78 dodge d60 front measures around 6-1/2" from center of axle tube to bottom of diff. I am not sure why this is so different from the rearend /forums/images/graemlins/confused.gif maybe I measured wrong. Axletubes are larger, at 3-1/8" diameter.
  13. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    What size tires do you want the measurements from?
  14. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    For what its worth before any specific specs are put up I've had a d60FF and a 14FF side by side, the 60 is manageable by one person the 14ff is definately a 2 person job, I'd guess the 60 weighs around 75-100lbs less...
    The axle shafts on the 60 look like twigs compared to a 14ff, the diff housing is probably 3" shorter than the 14ff ground clearance wise.....if you're building a light rig, the 60 is plenty....
  15. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    14ff is definetly heavy, I did mine by myself but used some furniture moving equipment to get it into place!
    Marty---
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I've installed a 14 bolt by myself before. Truck was just tall enough that with 29" tires I could easily roll it under there and then muscle it side to side.
