600 cfm q-jet
Discussion in 'The Garage' started by ssls6, Feb 18, 2005.
  1. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    Where is the cheapest place to find a rebuilt one? My 750 Q-jet (put on by the PO) runs way to rich. I'm looking for one with a manual choke.
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    There is no 600 cfm q-jet. From the factory they were either 750 or 795. An 850cfm version is available from Edelbrock. No 600 though. Check Autozone for a remanufactured q-jet. Pretty good deal if I remember correctly.
  3. ssls6
    Jan 5, 2005
    86
    Dallas, TX
    Maybe I mean 650? I'm pretty sure they made a 650 Rochester QJ for small block applications.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    nope, 750, 795, and 850. even an 850 QJet should work fine on a small block. unlike most other 4bbl carbs out there, the QJet will only feed the engine the air and fuel that it needs. yours isnt sized incorrectly, it probably just needs a tune or a rebuild.
  5. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
  6. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    There is no 600 cfm Rochester Quadra Jet.
    BUT
    Rochester did make a square bore carb called a 4 Jet that was around 600-650 CFM. GM used the Rochester 4GCs till they switched to the Qudrajet(4MV) in the mid 60s. They are hard to find now. They looked kind of similar to a Carter AFB.
    Just a little Rochester trivia I thought I would throw in.:grin:
  8. ssls6
    Jan 5, 2005
    86
    Dallas, TX
    I love learning something new. I just rebuild the 750 I already have then. Thanks.
