63 inch 88' 1/2 ton springs (I searched but no info for me)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by juanblzer, May 9, 2003.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    63 inch 88\' 1/2 ton springs (I searched but no info for me)
    Okay I dont have rear fenders... and I don't have a rear bumper that's unremovable or the original fueltank. Will these springs mount under my truck? Can I still use the shackle flip? I know it will move my axle back about a couple of inches but will the rear spring mount be able to mount to the frame? Thanks for all your help. /forums/images/graemlins/grin.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: 63 inch 88\' 1/2 ton springs (I searched but no info for me)
    Never heard of it or seen it, measure and see where it would put the rear mount if you use the stock front mount. I almost think you would have to move the front mount forward a little.
  3. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I want to keep the stock front mount. I don't want to move it at all. Too much of a PITA
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Talk to Watson at ORD. I think he ran 63" rears with stock front mounts and custom rear mounts before he went to coilovers in the back.
  5. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    to use the 63" spring you have to move your front hanger forward like 6-7" or you'll be adding that in wheelbase. I haven'e done mine yet to my Burb, but most of the extra length will be to the front as these springs are not offset like the stock ones. The center pin is actually pretty much centered on the spring.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I think someone was talking about running the 63" springs with the Springer rear suspension setup. You might PM Marv and see what he says/thinks about it.
    I think 63's and a Springer would flex like mad.
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i have the springer setup and am looking at doing this.
    i am starting on my truck kind of back to square one now. so i got time. i measured it out and the rear hanger has a 6 inch spread on the rivets. so remove the rivets and slide it back the 6 inches. then it will bolt right up to my springer setup. im going to PM marv about his thoughts. i will update this when i find out.
    Grant
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Honestly, IMO, there is such a thing as "too much flex". 57s on a Springer/Ak57 are on the edge, over by some people's estimation. 63s with proper shackle angle should be all you require. Of course, that's just my opinion.
