63 inch spring???????
Discussion in 'The Garage' started by Supreme70, Oct 12, 2006.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    what do u get your 63 inch springs off of. Im running a shackle flip and cant decide if I want 56 or 63 in springs. anyone have any pro's and con's of the two???
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    88-98's and 99-06's have the 63 inch springs.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Are the 2wd springs the same as the 4x4 springs?
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    The only differance in the springs is the rate. they all are 64", not 63" and the spring eyes are centered
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    A little shorter spring height on the 99 and ups, the best I can tell. 2wd's sit a little lower than the 4wd's, but not by much. There's probably a million different payload capacities, so probably a bunch of different spring rates.
    Dunno if that answers your question or not.
  6. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    I ran 63" springs on my K5 with a shackle flip and belltech shackles for the past 2 years. They worked better than expected exept for the axle wrap.
    If I were to do it again, I would build a torque rod.
    As for the spring packs, I started with a set of springs out of a 98 1/2 ton 4wd (4 springs) when I pulled them out this year I was up to 10 springs per side. I had to add as time went because of the flex and stess that was put on them. They were still plenty flexy just a lot heavyer when I pulled them out.:D
    Hope this helps a bit.
    Ryan
  7. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    im running a 87 short box truck so with my shackle flip would I have to use a zero rate with the 63 inch springs, I also have the 6 inch shackles.
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    64's require more fab work if u want to keep the axle at or close to the stock location
  9. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    Well does any one know if running a set of 56 inch springs with the 30 inch from end to pin to the front,if that would center the axle in the wheel well. I am running a 4 inch shackle flip from diy4x with a 6 inch shackle.
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    that would move the axle back 4", not center it
  11. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    doesnt dropping the spring down with the shackle flip move the axle forward, since you are changing the bolting location in the rear 8 inchs down from stock? it looks like it rolled my 52 center pin forward.
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i dont believe so, i could be wrong, but it moves the axle forward more when you droop, and tilt the pinion up as well.
  13. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Would be pretty close (within a 1" or so) BUT the best way to find out is just mock it in there and see where it is at ride hight and adjust as needed. Worked for me. Didn't take much time either.
    Hope that helps a bit
    Ryan
  14. divorced
    Jul 20, 2004
    5,115
    Yes, about an inch or so.
  15. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    so using a 56 inch spring, with the 26 inch to pin in th front with a zero rate would center it.
