63 inch springs
Discussion in 'The Garage' started by eightyone, Jan 7, 2006.
  1. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    what truck would i find 63 inch springs under? thanks
  2. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    [SIZE=-1]Most 88-98 Chevy/GMC 1/2-tons have the 63" springs.
    Al
    [/SIZE]
  3. eightyone
    Apr 25, 2004
    292
    long island
    thank you
  4. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    No prob.
  5. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    Do you use the stock hangers relocated? Where does the axle end up in the frame?
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    It depends on what vehicle you are putting them on. On a Blazer you will have to relocate front and rear mounts. You can move the axle back a few inches(IIRC 5 or so) before it starts to contact the fuel tank.
  7. jagermiester
    jagermiester 1/2 ton status
    Jan 3, 2006
    100
    NV
    Not true on a blazer and a longbed you only have to move the rear ward mount (I have done them both 90 jimmy, 73 blazer, andd 82 k30) I will be doing my new short box shortly and will let you know how that works out.
  8. kmodi
    kmodi Registered Member
    Nov 9, 2005
    56
    Atlanta GA
    how far do you have to move the mount rearward? i have an ord shackle flip and am looking to have an overall lift of 6" would stock 63's give me that or would i need custom packs? add a leaf?
  9. jagermiester
    Jan 3, 2006
    100
    NV
    The 63's give you no lift them selves so you would need a 2" lift 63. Or if you want add an overload. Also the shackle flip ends up being all the way at the end of a blazer frame right before it slopes down (last 2 to 3 inches of the frame) You also have to run a small spacer between the bottom of the frame and the bottom of the shackle flip due to the little knob under the bodymount.
  10. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    How far was your rear axle moved back?
  11. jagermiester
    Jan 3, 2006
    100
    NV
    Originally it was 4.5 but then I changed it to 7.5
  12. jagermiester
    Jan 3, 2006
    100
    NV
  13. jagermiester
    Jan 3, 2006
    100
    NV
  14. jagermiester
    Jan 3, 2006
    100
    NV
  15. jagermiester
    Jan 3, 2006
    100
    NV
    Im 5'8" and the suspension is not maxed out
