63" spring eye bolt size?
Discussion in 'The Garage' started by 1-8-4-3-6-5-7-2, Sep 26, 2006.
  1. 1-8-4-3-6-5-7-2
    1-8-4-3-6-5-7-2 Registered Member
    Jun 16, 2006
    58
    In the Garage
    Does anyone know the diameter of the spring eye bolts on 63" springs? I'm not sure if they're metric or standard? They will be from an '89 C1500 if I get them.
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    they are metric, i forget the size... i just ran a 9/16" bit throught the bushing, made everything much easier and cheaper...unless you have to buy the bit.
    It only took out a very little bit of the sleeve though.
  3. 1-8-4-3-6-5-7-2
    Jun 16, 2006
    58
    In the Garage
    Thanks. Do you think the metal sleeve would be thick enough to run a 5/8" bit through it? The vehicle they are going on I *think* has 5/8" bolts now, so the holes in the habgers are 5/8".
  4. 79k20350
    Nov 22, 2004
    7,757
    Ct
    they should be thick enough to fit 5/8" but if its a chevy than its 9/16"
  5. 1-8-4-3-6-5-7-2
    Jun 16, 2006
    58
    In the Garage
    Thanks. The springs are going on the back of a *gasp* '79 Bronco... I'm thinking the bolts are 5/8", but my tape measure isn't the most accurate tool to use for measuring bolt diameters... :haha:
