63" spring swap
Discussion in 'The Garage' started by PsychoticDeadGuy, Sep 25, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i did the search but couldnt find any writeups on the swap. i just got a pair of 63's today at pick-n-pull. they are super soft...i can tell just by jumping on them compared to the 52s. so, i need to see a write up on the swap if there is one...thanks
  2. PsychoticDeadGuy
    Jan 8, 2005
    753
    anyone? i want to do this pretty soon...any help?
  3. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    several members have done it! cybersniper and kidjethro come to mind first. they both have blazer chassis. i did it on a k10 longbed frame but not sure that will help if you are doing the k5 stuff. what do you need to know? :D
  4. PsychoticDeadGuy
    Jan 8, 2005
    753
    i would like to see pics of where all the mounts went and some of the steps in putting it all together...
  5. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    all you have to do is move your front spring hangers foward and adjust your rear hangers accordingly. it's real simple to do. my front mounts are under my body mounts and did a shackle flip on the rear. i look and see if i have some pics.
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
  7. ksblaze83
    ksblaze83 1/2 ton status
    Sep 11, 2004
    329
    Topeka, KS
    seventyk5 did a 57/63 swap ....here is one of the articles
    linky
    Here is the write-up...click here
    not a whole lot of pics of the 63's but should help you some
  8. PsychoticDeadGuy
    Jan 8, 2005
    753
    ya, thanks...i will be keeping the axle centerd in the wheel well for the most part...the departure angle is great on that truck but i dont like the look of the tires being outside of the fender well. thanks for the link...
  9. ksblaze83
    Sep 11, 2004
    329
    Topeka, KS
    Like he said, he put his gas tank basically up into the bed of the blazer, IIRC he was able to run his backseat fine though
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Here's a link to a thread on my clubs website about my swap.
    http://www.norcalbigdawgs.net/phpBB2/viewtopic.php?t=7265
    The pictures in the first post are broken, but further down theres a link to them. The post pretty much explained what I had to do to make it work. If ya have any other questions, go ahead and ask. :)
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You might take a look at running a longer shackle with it also, the longer spring will appreciate some more swing. We have a 6" version just for that purpose.
    Knowing that a bit more shackle angle than stock will help you out with a longer shackle, you should probably look at moving the front forward about 5" and the rear back about 6". This should keep the axle pretty well centered and put a bit more angle on the shackle.
  12. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, what about lift height? right now i have stock 52's with ORD 4" shackle flip and zero rates...on top of a 14bff. i dont want it to sit any higher than it is right now...possible with 6" shackles?
