63 swap angle check*more pics*
Discussion in 'The Garage' started by clarkjw24, Nov 23, 2005.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    63 swap done. Whatcha think about the shackle angle. Sorry for the crappy pics, I can't get enough light in the shopl
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Looks good.
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    that is a decent shackle angle, but i would make it at more of an angle to maximize the droop that you can get out of those springs. there already pretty flat so you wont get very much up travel, but if you get the angle to be greater then you can maximize your suspension travel. your shackle angle is good for a spring that has more arch to it.
  4. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    And some better ones of the spring swap
    This side hasn't been cut yet. I'm still waiting to do the front and level the truck back before any serious trimming.
    Heres the gas tank pic.
  5. PsychoticDeadGuy
    Jan 8, 2005
    753
    wow, sweet truck. 52s up front? or soon? I would like to see some flex shots.
  6. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Thanks, 52s are going in a couple weeks from now. I've got to make a parts delivery down in GA next weekend so I should be able to get them in the next weekend.
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you definetly need a steeper angle. mine w/ 56's are alot steeper than that. move up too the next bolt hole and that should do it. to get full use of droop you need it steeper. my angle look real steep, but it never folds over and i have around 5" droop-thats just shackle, not spring. P.s. i have the same shackles as you.
  8. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I'm thinking the angle will increase once I put my tool boxes and supplies on it. I can stand in the back of it and it will squat another 1 1/2". I'll be carrying another 200lbs of tools, parts, and spare.
  9. PsychoticDeadGuy
    Jan 8, 2005
    753
    You just cut a hole in the floor to fit the tank and bolted it down right? how do you like it? i want to do this or something similar.
  10. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Yeah pretty much just cut a hole and sit it in there. I haven't wheeled it yet but I won't have to worry about busting my tank anymore. I should have took some pics of the underside. Its beat to crap but there is tons of clearance now. I plan to build a cover and incorporate a spare tire mount soon.
  11. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    That truck is just too cool :bow:
    Is that a motor I see in the top picture, in your shop :wink1: :p:
    James
  12. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Looks very good! :waytogo:
  13. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    clarkjw24 do you have any pics of how you mounted the tank. did you have to move your body mounts or any crossmembers?
  14. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I rotated it 90 degrees clockwise. It just did fit between the body mounts. I was able to keep all the crossmembers also.
  15. muddyblzr
    Nov 2, 2004
    623
    the one that connect to the driveside shock mount was too high on mine. i thought about rotating it and probably should have but im gonna put a 90 degree elbow on the gas tank so i can put my filler neck on my tailgate.
    what is holding your tank in?
  16. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    just a tight fit right now:doah: I wheeled it this weekend and it didn't fall out but I'm going to take some 1" x .25 stock and make a bolt down ring prob.
