63's, 205 pto, propane carb
Discussion in 'The Garage' started by Zeus33rd, May 13, 2005.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I went to the junk yard today to pick up some 63's for my truck-
    Donor truck-
    Found a couple other interesting items out there too. Found this 205 from '86 dodge 1 ton with a PTO and hydraulic pump on the side. Truck had a dump bed-
    Also on the same truck was this propane setup-
    And a couple random junk yard pictures-
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    That second to last pic is sickening
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Was a 1/2 ton. No motor, tranny or t-case. Had been wrecked and thrashed before he grabbed it with the loader. Nothing special. ;)
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    first junk yard pic, hope that is a double wall top on that jimmy to the left you score the hydro pump and pto off the 205?
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Double wall roof? What Jimmy?
    I thought about snaggin that PTO thing with the pump, then I wondered what I'd do with it... :confused:
    I might go back sometime and snag the propane stuff though. :grin:
  6. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    It still looks like there were a lot of good rust-free parts left on it. I know stuff like that happens all the time out there though, but it still hurts to watch when we have trucks literally disintegrating left and right. And yeah you should get that propane setup just so you can have it. :cool1:
  7. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,623
    612
    Hooper, Utah 84315
    Go get the propane stuff, love my set up and even if you didn't use it I'm sure you could sell it and make a buck, not to the cheap bastards on here :D but E-bay would work. Heck I might take it and put it on my Blazer instead of fuel injection. The PTO would be cool just to have
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    It wasn't goint to the crusher, he was just getting it out of the pile so the guy on the left in the picture could pull the axles out of it... He had a 78 K5 on 35's with 3.08's. This truck had 3.73's. Great swap for him. The junkyard guys got the truck out of the pile, put it up on a stationary stand so the guy could work at eye level and let him use the air tools. When the guy was done, they stuck it back in its original spot.
    As far as picking up the propane setup, I think it's gonna have to wait for awhile. My gf is gonna kill me if I spend anymore money on truck. Just gettting those springs and a set of exhaust manifolds made her a bit bent out of shape. Understandable though I guess- In the last month- beadlocks, doubler, 12k Warn winch, new carb, all new power steering pump and box. :crazy: So hopefully the propane stuff will be there in a few weeks. I'm pretty sure it will... that truck has been there for months.
  9. 79 blazer
    79 blazer 1/2 ton status
    Dec 29, 2003
    114
    FORT COLLINS,CO
    i would get that pto pump so i could run a hydro winch without using the power steering
  10. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    The hydro pump would be cool, but wouldn't have much of a use if you already have a winch.
  11. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    The second to the last. Two tone brown truck. *sniff*
  12. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I'd be all over that pto hydro pump. My current dump truck uses electric hydro which is a bit weak for a 10.5' steel dump bed.
  13. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    How does the PTO from the 205 control a dump truck bed? hydraulics?
  14. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Yep, it's just a hydro pump that's run by the gears in the t/c.
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay cool, thanks Mike.
  16. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Seems theres some interest in that PTO thing... So I guess I'll head back out there tommorrow and see what I can get it for. Prolly find out about the propane set up too. ;)
  17. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    You probaly need a special trany to run a pto. Or atleased a manual tranny.
  18. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    or a 203 or 205 to turn it... oddly enough, he's got both? or did you miss the part about having the doubler? :confused:
  19. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    I think you miss understod me. I am meaning that there needs to be something in the tranny to run the pto from the engine. Unless I am just thinking of a two wheel drive truck.
  20. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    The PTO runs off the t-case in this case. However, I think there are some that run directly off a tranny which may be what you're thinking of.
