64.5" long rear driveshaft, will I have vibe problems with thick tubing?
Discussion in 'The Garage' started by 72THING, Nov 25, 2003.
  1. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    64.5\" long rear driveshaft, will I have vibe problems with thick tubing?
    I have a really long rear driveshaft (64.5") and bent it climbing some ledges. It vibrates some, but I was gonna keep it as a spare and get a new one built. I was considering thick(er) wall tubing, possibly .120" wall. Right now I think its either .083" or .095". I talked to Jess at HAD and he was reluctant to use .120 in fear that it would vibrate at highway speeds. What's your opinion or real-world experience? Thanks,
    Will
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Re: 64.5\" long rear driveshaft, will I have vibe problems with thick tubing?
    I'm not an expert like Jesse, all I can offer is my experience with a really thick wall driveshaft. My rear shaft was built by a guy in moab for me when I destroyed my stock shaft. The stock shaft was 42" collapsed length and was .083" wall.
    The replacement is .300" wall at the ends and was turned down to .188" for the center 30" or so. It runs smooth and hasn't been balanced (yet).
    I can understand that the extra mass in rotation could vibrate if it's out of balance even a little, but if it runs true it shouldn't vibrate...
    I run 4.56's so driveshaft rpm is up there at cruising speed.
    Rene
  3. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    Thanks for replying, Rene. I think I'm gonna go ahead with a .120" wall shaft when I get the money. I have faith that Jesse can balance it to run true. For the mean time, I'll continue to run my slightly bent driveshaft. And actually I think I bent it back some because it doesn't seen to vibrate as bad as it did.
    Will
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    I agree with rene, as long as the weld arent boogered up and the the tubing is true, you should have any probs. Only thing i can see is with the thicker steel, you will have more mass spinning around, and compared to smaller d/s's might need more counter weight if it was out of balance.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    64.5" is fine, you can use up to around 72 to 74" without havin problems, light duty 1/2 ton longbed 2wd pickups commonly run 74" single rear shaft, so you will be fine for sure
    good luck
