64 Rear Flex Pics
Discussion in 'The Garage' started by HELLBENT DESIGNS, May 2, 2005.
  1. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    pushed the truck outside and had a thought :screwy: i don't have a forklift to test flex for the 52's and 64's, but i do have a tractor :D bottom of rear tire was 34" front tire never showed any signs of lifting but i got scared :yikes:
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    niiiiiice :waytogo: Now all you need is a shackle flip :D
    You gonna have that bish ready for DR05?
  3. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    i could gain some droop with a flip cause my rear shackle hit the hangers. got the tranny putting the cam in today! should have engine /tranny/ t-cases in this week. hopefully there isn't too long a waiting list from HAD for shafts? yup i will be ready DR05 :waytogo:
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Are those lift spring 63's?? They dont look like they are flexing as well as they should be, maybe its just the non shackle flip that makes it look different.
  5. timmay
    timmay Registered Member
    Oct 24, 2004
    62
    Here
    Looks good :thumb: A shackle flip would be cool though.
  6. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Hopefully not cuz I need one too :blush:
  7. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    they are 5" lift. i thought about doing a no-lift shackle flip but gonna see what this setup does first! so how much flex is right? how far should wheel come up before lifting another tire? or what is a respectable rti for tire height?
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Well i just noticed that your springs didnt flatten out alot which is why I asked if they were lift springs, your front springs look like they are taking all of the flex since the main leaf is all fanned out from the rest, you might want to put a clamp on them to prevent from bending your springs. Id lift it up higher and see how high you can go :D
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    And another thing that I just realized is that you dont have any weight back there whihc will prevent your springs from flexing better. :)
  10. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    yeah, the rear will have another 400 lbs on it after fuel cell (full) batteries cage etc.
  11. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    what kinda bead locks are ya running?
  12. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    looking good
  13. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    how many inches from the bottom of the rear tire to the ground?
  14. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    badlands offroad, i heard they stopped making them. i would go with cyberfire's if you want weld ons i bought mine when he was moving his shop or i would have went with his. put the clamp on the lh front spring and lifted it up again! 44" to the ground before rh rear lifted. pic :D
  15. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    whats your wheel base?
  16. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    right at 120" :D
  17. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i think i said this befor but...... no rear disks?
  18. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    ok here yah go, just haven't had timme to pull the rear apart. :waytogo:
  19. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    what hoses did you get???
  20. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    1979 chevette, another member posted they worked good so i am gonna give it a try! they were $14 buck each :waytogo:
