64" rear spring swap, any body done it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Alex_B, Nov 2, 2006.
  1. Alex_B
    Alex_B Registered Member
    Feb 28, 2006
    33
    Newfoundland, Canada
    If I were to go from a 56" spring to a 63" would I neen to move my spring hanger.
    I've already got the 4" lift ORD spring hanger and there 6" long shackels.:D
  2. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    search my friend, im in the middle of doing it,. new brackets front and rear:) 113 wheelbase. my front is moved 2"
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yep, i did mine over the summer. if you wana keep the axle in stock location u need to move both hangers
  4. lar300mag
    lar300mag 1/2 ton status
    Mar 17, 2006
    258
    TEXAS
    Just got mine done last week. I moved the front hanger forward 5" and the rear I used ORD 2 1/2" shackle flip with there 6" HD shackle and bolted it to the factory location for the 56" springs. I also went with the 5" lift Tuff Country 64" rear spring. As far as I can tell, it moved the axle forward about 1", at full compression, it should be real close to the factory bumpstop
  5. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    i am doing the opposite, moving the rear mount only.. making my own shackel and reverse shackel... hopefully with my front moved forward ill be at around 112 113 ish, muhahhaa
