64" rears are in!!!!!!!!!!
Discussion in 'The Garage' started by rubbinz raczn, Jan 17, 2005.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    got the 64's in tonight:D i was hoping to get the 56's in the front also, but got off on another tangent this morning.(pulling seat- floor mat- seat belts etc.) you can see in pic the old front hanger mount, 22 inches forward from stock. rear hanger mount moved about 10. if i leave 6 inches of frame rail behind rear hanger i can still hack 15 inches off rear frame:hack:
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what is the wheelbase gonna be?
  3. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    if i left the front stock it would be 118" i will gain 2 inches for sure with the front spring swap. i may also use zero rates i have lying around to push front forward total 3-1/2 inches so ballpark 122" max:D
  4. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    why no shackle flip?
  5. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    rears are 5" lift!
  6. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    working in the hay barn eh?? hope your not using torches......
  7. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    no torches but grinding the rivet heads off i had to be careful. so far 60 in think!:D
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You're going to have some serious drive line angles there aren't you??
  9. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    yes, i can see they're lift springs, but i was wondering why you used lift springs rather than a shackle flip.
  10. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    you mean when it flexes? maybe, i will be running 1410 shafts so that should help. net lift should be 5 inches or less so hopefully not too bad!
  11. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    a few reasons. by the time i bought the flip,bought used springs and replaced bushings i have about the same into the springs. i can also use the stock shackle setup. do shackle flips flex more or just lift? i may be giving up a little flex with a lift spring but believe me these things flex:D you can push down on rear frame rails and compress the springs a bunch! right or wrong this is the direction i am heading in so i will have input all the way. so far i am happy with results! getting ready to do the 56" front swap right now:hack: hope to get it in and get pics up tonight:D
