64" springs and DIY shackles installed *Flex Pics*
Discussion in 'The Garage' started by muddermilitia, Dec 31, 2006.
  1. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I got my 7" long shackles from kert the other day, painted them and installed them along with my 64" rear springs
    I gained 5.5" of wheelbase but lost just over an inch of lift. A pair of zero rates should just about level it off.
    29" under the rear tire. Once I get my 52's up front and a little more weight in the rear that number should increase more
  2. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    wow man sweet play there
  3. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Hey Man!
    If you're truck hasta take a [​IMG]tell him to go back around the garage will ya! Sheesh! :haha:
    Nice [​IMG] Can't wait to see what she's like with the zero's in.
    Manny
  4. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    :haha: Thats funny I just saw that stain on the ground, didnt come from my truck though
  5. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Yeah, yeah. The first sign of a problem is when the truth is[​IMG]
    Hey I think you may need to upgrade the undercarriage a little bit. Here's a little somethin' that'll help stop that little problem
    Let us know how they fit. :haha:
    Manny
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You're not even close to maxxed out yet...with those springs you should see 40" or more under a tire.
    Rene
  7. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    thats kinda what I thought too.
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I need to take some pic's of my junk flex'd out. Had 49" under a rear tire using the forklift at work...:p: I stopped because I thought it was gonna flop before lifting a tire, and that would have been a bit awkward to explain. :doah:
    Rene
  9. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    2nd floor, lingerie wearing women, 4x4's and guns. going up!
    Looks good!
  10. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Thanks for the excellent reference pics, man!!
    They will really help when it's time to do mine.
  11. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I think having the added weight of the blazer body increases your flex. Last september I wheeled the truck after I put the cab on and the flex sucked.
    Here it is with the stock springs in the rear. You can see that the driver's side rear tire is off the ground [​IMG]
    That's why after the suspension is done and the 1-tons are in I gotta finish up my flatbed and im gonna add a toolbox, spare tire, and storage for spare parts. Id like to keep the stock 31 gallon gas tank too, just so I can fill it up to add more weight to the rear
  12. oll' bessy
    oll' bessy Registered Member
    Mar 6, 2005
    14
    big bear, ca.
    are those stock springs? or lift springs? im concidering the same thing and am trying to figure what lift i need in the springs. looks great by the way, nice flex :saweet:
  13. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Stock 1/2 ton springs off of a newer (IFS) Chevy but using a 4" shackle flip.
  14. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Yep, I believe they came off a 98 or 2000 era chevy 1/2 ton 4X4 and I flipped the ORD hangers from side to side(so they angled back) and I moved the hangers farther back
  15. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    have u compressed the rear enough and see if the diff cover hits the gas tank?
  16. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Before I installed the shackles, I had used my jack to raise the rear axle way up, more than I think It would ever go in real world conditions and the cover did not hit the tank.
    Although I have to flip around the rear (flexible) brake line where it mounts to the axle. But keep in mind this is all with a 10 bolt. So the 14-bolt will be different.
    I still need to install a zero rate in the rear, but I am undecided if I will move the axle back or not. If i do move it then I am gonna have to do something about the tank. Raise it up or put a fuel cell in it. Opinions?
  17. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    did u take the factory skid plate already off?
  18. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    looking good. if you get zero rates I would leave the axle centered. How much more wheelbase do you really need.
    as for it hitting the tank, are you going to be jumping the truck? if not then the axle centersection doesn't move that much. when you are flexing one side goes up and one down. the centersection pretty much stays put.
    I would keep the tank where it is, or move it up inthe frame slightly. you need weight behind the axle for going down hills. last thing you want to do is stand it on its nose.
  19. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Also depends(not mannys lol;) ) on what diff cover your going to run on your 14ff. Some hit the tank and some dont.
    Looks good though!:D
  20. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yea u still got alot left. ur right shackle angle is almost how it is when not flexed haha. jack that sucker up more! looks good
