65 Impala 327 Idle problems
Discussion in 'Other Rides' started by muddbogg89, Apr 2, 2003.
  1. muddbogg89
    muddbogg89 Registered Member
    Mar 19, 2002
    97
    Chicago(suburbs)
    The motor is a 327/250hp 130k mi un rebuilt as far as i know and stock except Edelbrock carb and intake and HEI.
    the idle is all over the place it jumps between 600 and 1200 rpm in gear.Other than that it runs fine. The carb is about 8yrs old with 50k on it
    What could this be,Timing chain,carb or what?
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    Vaccum leak? maybe? Try using a small propane torch unlit around any place Vaccum could leak from, If it is leaking the propane will pick the idle up,
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Could be the advance springs in the distributor too.
    John
  4. muddbogg89
    Mar 19, 2002
    97
    Chicago(suburbs)
    I'll give the propane a try.
