66 Chevy specs? What rear axle?
Discussion in 'The Garage' started by sled_dog, Dec 5, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I found a 66 3/4 ton 2wd Chevy over in Jersey. It looks pretty nice and is the right price so I am thinking i may pick it up for my daily driver/tow vehicle. My dad is with the idea cause he likes those older Chevys. I am trying to find out what rear it would have though. I'm guessing an Eaton but I don't know for a fact. For a year round daily driver it would have to have a good posi or locker thanks to our wonderful weather here in PA.
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    My guess would be an Eaton or D60 rear. /forums/images/graemlins/thinking.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Most likely an Eaton 19 spline I believe. Strong axle. Has a rear diff cover and also drops the center section like a 9" Ford. My buddies 66 1/2 ton is 4.57 gears from the factory and I don't know if GM used any other ratio. His is a 12 bolt though being half ton.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    this says its 4.56, its an ebay auction and reserve isn't met yet, hoping its like a grand.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    If it is big and round and looks like a big arse Ford 9" then it is an Eaton. Strong axle. I believe there is or was a Detroit locker available for it. (some from the factory I believe)
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    66 is also nice for the fact that it doesn't need to go threw emmision (should you have them in your area). They are simple, the body style is cool and there are alot of parts available.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Only problem I can forsee is braking, but I'm sure someone makes a nice brake setup for them. Since it would be a tow vehicle need good brakes. Has some really nice rims with it too, nice motor as well, probably wants more than I want to spend. My dad may help me out since he likes these. In PA 78 and older don't need emissions so I am looking for an older rig.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    parts are hard to find and expensive for the GM Eaton axles, they were used from 47-72 under 3/4 and 1 ton trucks 2wd and 4x4 both. but under mostly the 2wd trucks with coils, you most likely have dana 60 under the 4x4, but it still could be the H052 axle
    4.57 was in the Eatons and 4.56 in the danas
    4.10 was available for both axles, and thats all for the eatons but dana 60 were occasionally made with 3.54 although very uncommon and reserved for certain big block combos for 68-72 and in which only would be 2wd anyways
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    disc brake kits for a 14ff work for them. its way cheaper than the pads at 156.00 the wheel cylinders at 65.00 ech and the drums at 290.00 apiece. so i would just do disc.
    i also have a pic of an eaton in my webshots. at least it used to be there. if not ill get it back up.
    69k5
  10. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    Eatons had 4.10, 4,56, and 5.13's. Randys R&P makes replacement 4.10's for them. Parts are expensive for them buts its not an issue because they very rarely go bad. The Eatons were used from 46-72 in 3/4 and 1 tons. They were available from GM with Detroits, which were called no-spins then. 14 bolt axles and spiders or detroits will interchange if you want to swap to fine splines - but the stockers hold up just fine.
  11. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Get the front suspension from a 71-87 2wd 3/4ton. It will bolt up. REZ engineering makes a kit to bolt on a 73-87 power steering sector. Find a power brake set up from a 71-72. You'll be set.
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    [hijack/]
    wher did you learn this? im just asking b/c i am putting an eaton in my blazer as soon as i get off my but and hang it in there. i have been looking all over the net for info to educate myself and hadnt heard that before. ive looked here, 67-72, and on pbb just not alot of info out there. i like the big splines personally.
    [end hijack/]
    sorry about the hijack
    69k5
  13. cornfed
    Oct 15, 2001
    295
    washougal wa
    I dont remember where I heard this but a friend tried it with a 14-bolt detroit insert and axles and it works - except the new 14 bolt detroit didnt last the day, and the 30-plus year old eaton had endured many years of serious abuse before it let go.
  14. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i did some more searching after that post and saw where people had done i. they always said the dsame thing that it wasnt as strong. i think ill just kkep mine the way it is.
    69k5
