67 2wd...how can I lift it?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, Jun 9, 2003.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I have a 67 Chevy C-10 short bed fleetside as my back-up driver. I'd just like to know what I can do to lift it. I don't see body lifts for this year (Not to mention, I'm afraid to undo the body mounts for rust reasons...) and I havent seen any coil lifts for it...
  2. prerunner1982
    prerunner1982 1/2 ton status
    Nov 4, 2002
    235
    Oklahoma
    you can add spring spacers, or even put in 1 ton coils. have heard of guys converting newer (88+) lift spindles to fit 73-87s. not sure how they would fit the 67-72s...
  3. 71chevy2wd
    71chevy2wd Registered Member
    May 19, 2003
    7
    Are the front brakes drum or disc???? if they are drum, convert it to disc, and use fabtech's long travel suspension .
    If you install coil spacers or 1 ton springs, you only top out your suspension and wont have any droop.
  4. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Drum, it's the 6 lug 2wd year. 68, I believe, they switched to 5 lug. What's the best way to convert to disk? Can I use spindles from newer GM trucks (73-87)?
  5. 71chevy2wd
    May 19, 2003
    7
    I've been told that the '73-'87 spindles and ball joints will bolt up the the a arms without any problems.
    I have looked up the numbers in a parts catalog and the ball joint #'s are the same with trucks running disc brakes.
    I wish a company would step up to the plate and make lifted spindles for that style truck. I would install that set up in a heartbeat. I'm having my 3/4 ton spindles redone to give me more lift.
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Up until recently I have only seen info on converting to disc brakes with 73-87 spindles (and as a result 5 lug wheels for 1/2 tons). But recently there was a post on the 67-72 site about a cheap 6 lug conversion using newer light duty 3/4 ton spindles.
    Check out this thread /forums/images/graemlins/thumb.gif
  7. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    PERFECT!!!! Thanks so much. It looks like he used the parts from a light duty 2500 truck. Those came with 6 lug 14 bolts. So I gotta find a 6-lug 3/4 ton truck in the boneyard and go to town! Thanks man, just the info I needed.... /forums/images/graemlins/thumb.gif
