$67 shipped Clocking Ring NP208/241 D-300
Discussion in 'Vendor Forum' started by greatlakeoffroad, Sep 18, 2005.
  1. greatlakeoffroad
    greatlakeoffroad Registered Member
    Sep 16, 2005
    69
    Indiana
    As it states above this is $67 shipped to your door you get everthing as pictured. Which includes the studs, nyloc nuts and countersunk allen head screws. This rotates a passengers side drop t-case of the models listed above up to give more ground clearance it does not lower the t-case to give better driveshaft angles. Thanks Shawn
  2. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    Sent you an e-mail on the clocking ring and diff cover.
    George
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Have a bigger pic of that setup... either my eyes are going bad or it's too small to see all the parts :doah:
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Does that work for all transmissions??
  5. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    still have any of these left???
  6. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    That's a great price on those things! :eek1:
    I've ran a similar ring for about 2 years on my 89 with a 241 with ZERO problems. It's an afternoon install that gains a TON of ground clearance!
    I'll answer the tranny question, if you've got one of the cases listed above, it will work!
  7. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    what about your shifter? does it remain in the same spot or do you have to mod it at all?
  8. Kyle89K5
    2,273
    OKLAHOMA
    The shifter is a hinged rod setup so all you have to do is adjust out the linkage. Takes maybe 5 minutes to adjust it where it needs to be.
    You're rear driveshaft will be a little bit long (mine was, but I never had a problem with it bottoming out, more piece of mind ;) ), but combine this kit with a zero rate and move the axle back, and it's perfect. The front shaft will be short, and clocked all the way up, you'll need to grind out the CV for clearance and prb shim the front axle a little. A new HA shaft would be the trick.
    A 1" body lift will let you clock the thing FLAT with maybe only a small bit of floorboard clearancing.
    Didn't mean to hi-jack the thread Shawn, but these rings kick ass. Talk about a cheap way to gain some clearance
    :thumb:
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    just the one, or are you selling mulitple units?
  10. muddyblzr
    Nov 2, 2004
    623
    ahh i see thats kinda what i figured but had to make sure, i have a fixed yoke 241 my driveshaft should be plenty long. my front shaft ill clearance the cv some and probably run a shim for good measure.
    thanks for the info!
  11. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    He doesn't have a PM set up.
  12. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    after playing with my 241 tonight a flat belly pan would be cake to do. I need one of these.
  13. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Has anyone heard from this guy?? Sent an email...no response....no pm......no website listed??? WTH???
  14. Mudgod
    Dec 19, 2004
    92
    Gilmer, TX
    My came in today. And I sent him many back a forth e-mails. He got back with me always on the same day. So I don't know.
  15. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Does this bolt in between the Tranny/T-case or does it just rotate the one section of the T-case?
  16. greatlakeoffroad
    Sep 16, 2005
    69
    Indiana
    It bolts between the t-case and tranny not sure how you can rotate just a portion of a one piece cast t-case? But if you can I'm all ears. Thanks Shawn
  17. hans999999
    hans999999 1/2 ton status
    Mar 9, 2005
    149
    southern connecticut
  18. greatlakeoffroad
    Sep 16, 2005
    69
    Indiana
    Sure how many you need? E-mail me to arrange payment. Thanks Shawn
  19. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I need one. Send me a pm or email. I have sent 2 emails and no response.
  20. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    how exactly do you install this? i cant understand how it all bolts together
