69-72 big block
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SilverJim, Sep 23, 2000.
  1. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    I have a 70 Jimmy that came with a 350/SM465/Dana 20. I retained the SM465, but swapped in a crate 502 HO and NP 205. The question is this: Does anybody know of a specific header I can use? I used small block motor mounts, because I couldn't find big block mounts for a 4x4 of that vintage. The small block mounts work fine. Clutch linkage in the way isn't a problem because I'm running a hydraulic setup. Any advice is appreciated, even if it requires swapping the mounts. I even ordered some mounts, but I'm pretty sure they were for a 4x2 version...they didn't fit.
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Other than being very jealous I don't know what to say. Been wanting to do the 502 thing ever since I heard of it. Not sure, but couldn't the 502 use the same headers as a 454? If so, then shouldn't be all that bad. Only other option would be to get the header kit that you weld up yourself.
  3. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    I just put a built 454 in my 71 and if there the same then hedman makes one...part number is 69110
    Theres No Replacement for Cubic Inches!
  4. SilverJim
    Sep 23, 2000
    105
    Evergreen
    so...anybody know where I can get big block motor mounts?
    1970 GMC Jimmy (still waiting to put the body BACK on the frame)
