69-72 truck every come in a 2wd 6 lug?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by dodgedude99, Aug 3, 2004.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    can anybody answer this?
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i think there was a drum style (pre71) that came with six lug 2wd. i did look up info but stoped there since i wanted to swap over to six lug 2wd. they mostly came in 5lug style.
    ARQ.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    All half ton trucks, 2 and 4 wheel drive, were 6 lug prior to 1971.
  4. sponsoredbydad
    sponsoredbydad Dune Slaying Sand Junkie Premium Member GMOTM Winner
    Mar 12, 2004
    2,334
    405
    Dana Point "So Cal" "The sue me state"
    I have both a 69 & 70 Blazer with 6 lug /forums/images/graemlins/k5.gif /forums/images/graemlins/cool.gif
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    are they front drum or disk brakes???
    ARQ.
  6. Blazer1970
    1,600
    Old Mission, MI
    ARQ.
    '71 was also the first year for front disc brakes.
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    yea, but was it a 6 lug 2wd or a 5lug 2wd?? I didn't run into any 2wd disk brak 6 luggers...
  8. Blazer1970
    1,600
    Old Mission, MI
    No such thing as 2WD 6 lug with disc brakes (at least until they went back to 6 lug on the 2WDs in 1999). Last year for 2WD 6 lug was 1970. First year for front discs was 1971. This sucks for the guys who have pre '71 2WDs, because there are no factory parts to convert to front discs unless you convert the whole truck to 5 lug.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes no disc brakes on anything til 71
    70 was last year for 6 lug 2wd
    and 4x4 didnt make it any different
    neither if they were blazers, no difference, the 2wd blazers were 5 lug after 70 also
    no 6 lug 2wd rotors were ever produced factory
    yes you can nowadays finally buy 6 lug front rotors 2wd, they are all aftermarket
    you can swap entire engine suspension cradle over to a 70-down truck from a 71-87 truck
    70 and up rear axles widened by 1.5" no matter if std or HD brakes 2" vs. 2.75" wide such as the Big10 pickups and any that had HD suspension options that increased GVW rating enough to require the thicker rotors and wider rear shoes.
    you can bolt the 2.75" brakes(from the backing plate out to the drum) to a '69-older axle and use 71-up shafts(31 3/16" long overall minus the studs) and convert the older axle over to 5 lug without any mods
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I am in the process of converting a 70 to disk, 5 lug by putting the 73 and up knuckles in the front, and 5lug axle shafts in the 12bolt, are you saying the shafts will not be the right fit?
    I could swap the axle all together but it's the coil suspension rear and i want to retain that.
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    70-82 shafts are all same length, youll be fine
    70 is still six lug shafts, but is 5 lug shaft length
    they waited one year to change them to 5 lug for 2wd
    the 4x4's 70-up use the same 6 lug shaft length as the 2wd's did in 70
