69-80's 350 oil filter on a '92 4.3L engine ?
Discussion in 'The Garage' started by R72K5, Apr 21, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    69-80\'s 350 oil filter on a \'92 4.3L engine ?
    will it work ? are they same ?
    thanks
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 69-80\'s 350 oil filter on a \'92 4.3L engine ?
    Nope.
    4.3 uses the PH 3980 Fram where the older 350s use PH 5 or PH 30. You can put a PH 3387A from the smaller GM cars on a 4.3 in a pinch, though.
    88-up 4wds use the 3980 as well.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what is the diff ? diameter, or ?
    thanks /forums/images/graemlins/laugh.gif
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep the diameter is quite a bit different. i think the lenght is close, not sure on the threads
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Threads should be the same. Diameter is much smaller as is the gasket surface.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    oh, well that sux
    thanks :D
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    Randy, keep in mind that a 4.3 is just a 5.7 with 2 cylinders cut out of the middle. while you may not be able to put the oil filter itself on, you could change the oil filter mounting adapter. i see no reason why it shouldnt work. they use the same gaskets.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    While I'm sure that's possible, I can't see why one would do it.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    4.3L is more different than that, ppl like to make it all sound simple like that and such, but there are more differences from a 4.3L casting to a 5.7L casting than simply being one cylinder length shorter.
    im not gonna attemtp swapping adapters since i do not know for sure if it will hurt the engine or not, cant afford to ruin the engine if it didnt work out i was just curious to see if i could use a 1218 on my brothers 92 s-10
    but answer looks to be no, so im not gonna try it
