69 drum to disc *DELETED*
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Humpback, Dec 23, 2001.
  1. Humpback
    Humpback Registered Member
    Jun 16, 2001
    37
    Post deleted by Humpback
  2. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    Re: 69 drum to disc
    best to find a donor axle to get all the parts on, you need knuckles out i think..... also need new brake lines a disk brake portioning valve, a booster from a 86 2wd CAN work but it requires drilling holes and other stuff..... best to just find the power brake setup off a 71-72 truck.... get the proptioning valve, booster, master cylinder, booster to firewall brackets, and pedal rod,
    i am currently doing this exact same swap but i chose to just bolt in a whole diffrent axle, which is probaly the easist way to go if you can locate one with the gear ratio you want
    68 SWB 4x4 1 of 1,449 made 327, 465 4 speed, rockwell tcase, dana44, 14 FF, <a target="_blank" href=http://communities.msn.com/68K10>http://communities.msn.com/68K10</a>
  3. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Re: 69 drum to disc
    It is possible to buy everything new except the booster brackets. The spindles, caliper brackets and hubs are available new from Spicer but they are expensive. A donor is definately the way to go, preferably later than '73. GM switched to bearings in the spindles around '73. You can use the brakes off of any GM 6 lug up to the early eighties for sure maybe even up to '91? The brake booster brackets and prop. valve can come off of any '70-'72 GM Pick-up with power DISC brakes. (you can use 3/4 ton brackets but the 3/4 ton has an extra bracket you don't need) GM still makes the prop. valves, I got one from ChevyDuty for $50. In-Line tube makes really nice brake lines for $150, well worth it. Get the brake hoses from an Off-Road place, I got Skyjacker, steel braided, for a 2"-4" lift for $50. Stock rubber ones are $30-$35 each! Your locking hubs should fit. You also need the outer axle shafts from a disc brake truck (also available new). Make sure you use Spicer U-joints on the axles! email me if you have any questions.
    Never said I could spell!
    '70 K-20 San Diego, CA
  4. Humpback
    Jun 16, 2001
    37
  5. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Re: 69 drum to disc
    glad to help.
    I know, I can't spell!
  6. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Re: 69 drum to disc
    Humpback, the guy who runs <a target="_blank" href=http://blazerworld.net/>http://blazerworld.net/</a> is selling a D44 with disk breaks. Check it out in the Nickle section on his site.
    '69 K-5/350/TH350/35's & 6" Lift
  7. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Re: 69 drum to disc
    I have a D44 out of a 1972 blazer for sale
    If you build it, the mud will fly!
    72 K5 blazer with a 427 tall deck and TH350/NP205 and 9"of lift with 40"tires.
