69' Front Axle Change out Question.
Discussion in 'The Garage' started by rencher2, Dec 3, 2005.
  1. rencher2
    rencher2 Registered Member
    Aug 31, 2005
    63
    Sitka,Alaska
    My 69' K20 has a Dana/Spicer closed knuckle front axle & I'm considering a Corporate 83' K20 front axle. Are the Differential Gears from the Original (dana/Spicer) interchangeable with the corporate ??? Also, leaf springs included will this match up with the 69' chassis???
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    dana is dana. corp is corp.
  3. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    That didnt answer my Question at all.
  4. sweetk30
    Nov 1, 2004
    25,547
    542
    yes it did. dana parts and corp parts wont swap. the axle it self will bolt up. but the internals wont swap over.
  5. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    what sweetk30 is trying to say is that a corporate ring and pinion, and a dana ring and pinion are completely different and will not interchange (swap the dana R&P with the one from the corporate.
    as for the leaf springs, your going to need to measure from spring center to spring center (on the axle) than if both the same, measure from spring eye to spring eye on one of the springs mainleaves.
    LUKE
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have seen such a swap up close on bigyellowjimmy's 1970 . The axle will bolt right in , and the steering will work , and the driveshaft will attach .
    None of the internals will be the same however , as mentioned previously . Two different axle designs , two different sizes of parts in the centersection .
  7. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    Thanks that is a little clearer, I'll have to buy the gears for the corporate,to match My Eaton Rear axle, How can I find out which ratio without opening the rear end?
  8. sweetk30
    Nov 1, 2004
    25,547
    542
    when was the last time you changed the axle oil? if you cant remember then time to drain and fill and look at code for ratio. most eatons were 4.10 or 4.56 some 3.73
    if the front still has the little bolt tag on the cover it will say gear size.
  9. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    So Blackblazer, you are saying that they will work right?
  10. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    This old thing doesnt have much at all left on it, any other suggestions?
  11. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    jack up the rear of the truck. mark a spot on the pinion yoke... and mark a spot on one of the tires... Rotate the tire one full revolution, while counting how many times the yoke spins... multiply that number by 2...
  12. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    Thanks Silver thats a good Idea, Im not real familliar with differential ratios , Does the front ratio have to be exactly the same as the rear? Forgive me I'm a Marine Deisel Mechanic.
  13. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    If you have 4.09's in the front and say 4;11s or 4;10s in the rear.. you will be alright, but any thing much more then that and and youll be binding your tcase
    by checking the rears with my method you sort of have to guesstimate how many times the yoke spun... so if it spins 4 times plus a little... then you have 4;10s, 4;09s, or 4;11s
    if it spins 4 and a half times its 4;56s
    so on and so on..
  14. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    Cool thanks Silver your info is great , Any suggestions on where to get a good deal on Corporate gears if needed?
  15. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    a lot of places.... you should pay around 150 for a set of them...
    i dunno whats in alaska as far as gears go... Are you setting them up youself?
    you might have to order them off the net...
  16. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    Yeah its nothin but net on this Island , I was just curious if you had an specific sites in mind. Yeah all myself.
  17. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    just go to randys ring and pinion site...
    ringpinion.com
  18. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i dont know how much access you have to junkyards, or just parts in general. but it might be easier and more cost effective to just go out and find a newer open knuckle front end with the gear ratio you want, buy it for 100 bucks and be done with it....
  19. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    No junkyards & shipping is outragous It would be cheaper to ship gears
  20. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    I saw one in So-Cal awile ago but it would take a year to ship at a reasonable price
