69' K20 Rear Axle (Solid)
Discussion in 'The Garage' started by rencher2, Oct 11, 2005.
  1. rencher2
    rencher2 Registered Member
    Aug 31, 2005
    63
    Sitka,Alaska
    What kind of Axle is on the rear of this Truck?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    i believe it would be an Eaton
  3. botboy
    botboy 1/2 ton status
    Aug 11, 2004
    225
    Delano, MN, USA
    Probably an eaton HO52 or HO72 full floater..does it have a removeable center section (like a ford 9")? Thats usually a dead giveaway that its an eaton rear.
  4. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    By removable center do you mean from the front ? if so thats correct.
  5. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    Anyone know the the stock gear ratio or ratios for the 69' K20 application?
  6. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Depends on engine.
    a 350 truck would have 4.11's stock
    a 250, 292, 307 truck would have 4.57's stock
    Of course they could be ordered optionally.
    The third gear ratio from the factory was 5.14, but these are usually under one ton's.
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Along with the Eaton possibility, it could also be a Dana 60.
    This is the Eaton:
    This is the Dana 60:
    :D :D
