'69 TH350/np205 is it ok?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ricktard84, Jul 27, 2001.
  1. Ricktard84
    Ricktard84 Registered Member
    Jun 25, 2001
    44
    TX
    \'69 TH350/np205 is it ok?
    I am currently looking into buying this combo from a guy. Is this year suitable. I don't know anything about changes in trannys, X-cases for GM's. He said it was fixed yoke on both ends. Is this the same set up as say an '80 350/205 just older. Anything I should be warned about? Thanks.
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Re: \'69 TH350/np205 is it ok?
    Its junk!!! Dont buy it just take it and box it up real nice and ship it to me to dispose of properly! [​IMG]
    Out of 100,000 sperm, YOU were the fastest?? [​IMG]
  3. Grim-Reaper
    7,385
    Atlanta
    Junk Junk Junk! send it to me and I'll make sure nobody gets taken again with this case. Becides it wouldn't fit well in you toyota.
    Now I am pretty sure that the 205 didn't come in GM till after 70. You may have a TH350 and a Dana20 case. Still all gear drive but not as desirable as a 205. 205s came slip yoke after 79. the fixed yoke is really a better choice but a slip yoke can be converted to fixed yoke.
    If you look at the back of a 205 between the rear output and the bearing suport cover for the front will be the mid shaft cover. It has 3 bolts on it. if it doesn't have that little cover it's not a 205. It's probably a 20.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    Grim-Reaper
  4. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    NO NO Grimmy! He has to send it to me so I can properly dispose of the way it should be! ( in my blazer ) [​IMG]
  5. Ricktard84
    Jun 25, 2001
    44
    TX
    I just read on this site under the specification section. I clicked on 1969. Well Th350/205 in that year. If this guy is BS'n me I can take it out of his arse. JK. It sounds legit, so I think I am going to get it. It's coming out of a '69 Blazer too.
  6. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK if you insist. Ill P/M you w/ my address, so I can get rid of it for you.
  7. Grim-Reaper
    7,385
    Atlanta
    Well look for the cover plate with the THREE bolts for the mid shaft. If that's there it should be a 205. There may be a tag on it also around the front out put. It's a rare find if it is the 205 if you haven't figure out from the way everybody tried to get you to send it to them [​IMG]
    Grim-Reaper
  8. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Everybody?? Its just me and you Grimmy. LOL!!
