6in too tippy?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Aug 31, 2001.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I'm kinda thinking 6" is getting a bit too high for center of gravity. A little too tippy should i get wider tires (wider stance) or should i lower to 4" and cut the fenders and get 36" Right now its running 35" W/ 6"
    87 k5, 6in, 35" BFG muds.
    Future Mods: KNfilter, Flowmaster Force2 Catback, change the 5.5 blocks and .5 addaleafs to 6in springs.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Depends on what you like to do - for the high speed stuff, 6" is stretching it a little, but for slow speed trails or rockcrawling, it's fine.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    I don't think I'd be the right person to answer this question :)
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  4. white_knight
    Feb 23, 2001
    1,171
    nia.com
    </a>
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    nah, it isnt too much. even in the mud. just have to be carefull
    i am going to do 6in and a 2 body. and run 42's or 39's.
    i have seen the same setup, it is good. a bit tippy at high speeds, but just be smart and you will be fine. besides, 4x4's are for trails an mud not speed. unless it is in mud.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    You must be one of those converter Exploder drivers... Cripes! First off it is a truck... not a corner carving Camaro w/ aftermarket suspension. I take cloverleafs as fast as most cars do and sure it tilts a bit but nothing even close to being a tip hazard. Like was stated, drive smart and you'll be fine. It also depends on the springs... softer springs such as TC EZ's tend to roll more... also bushings and body mounts come into play. If you are really worried about it go for a little wider stance or go w/ a 4" and 3" body lift
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  7. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I was driving my 6" suspension w/3" body lift Blazer in traffic the other day. Long story short, I had to stop quickly, but thought I might not make it in time. So I went to the median, where PART OF THE CURB HAD BEEN REMOVED! This took the wheel from my hand, and turned the truck all the way to the left @ about 40mph. The truck drove up on the median, skidding laterally down the center of the median, completely sideways. I came to a stop, and suprisingly didn't even loose a tire from my 16.5" rims!
    Not that I am proud to announce this little incident, but it certainly convinced me that my lifted Blazer does not have a center of gravity problem. Hope that helps you too.
    <font color=red>GOT MUD???</font color=red>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a> [​IMG]
  8. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i have 10" and 2" with 39" tires and it isnt 'tippy'
  9. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    have you considered changing your steering to a xover, it might help with that.
    phill
  10. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I would cut the fenders. Either way you will probably have to cut the fenders. 36s do not fit in the wheel wells. You will only be going up a half inch, so I would stay where you are at 6 inches. If you went bigger I would recomend putting a 4 inch lift on it.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
