6inch lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudmuncher, Jun 7, 2003.
  1. mudmuncher
    mudmuncher Newbie
    Oct 8, 2002
    4
    south louisiana
    i recently put a 6inch superlift on my 89 k5 and i cant seem to figure out where this popping sound is coming from.
    i hear the noise and feel it when i first take off and also when i speed up out of a turn or when i hit bumps. Any ideas would help.. thanks <font color="black"> </font>
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    U joints? How is your driveline angle?
  3. mudmuncher
    mudmuncher Newbie
    Oct 8, 2002
    4
    south louisiana
    i thought that it might be the u-joints, but how do you explain the noise when i go over bumps in the road?
    the springs i got had shims on them to tip the pinion up, so that angle isnt so bad, the joint at the case is at a pretty steep angle though, so that might be it. <font color="black"> </font>
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Could be lots of stuff, but the u-bolts being loose is likely. I've also had poly bushings make popping noises too. </font>
  5. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    When you go over a bump the suspension flexes changing your driveline angle. But it could be some of the other stuff too like loose Ubolt or body bushing.
  6. mudmuncher
    mudmuncher Newbie
    Oct 8, 2002
    4
    south louisiana
    thanks, i think im gonna check every bolt and nut related to the lift and if it still does it then ill see about a cv driveshaft from high angle driveline, i heard they eliminate all vibrations.
